Network Error
I am getting this message during every session now.
Network error Unable to connect to the unit S3Mix CS(AvidS3) Possible causes: ..... The only fix has been to quit PT --->quit Eucon ---> Turn off Wi-Fi---> Restart Eucon --> Restart PT --->turn Wi-Fi back on. Any others with this problem? It seems to be getting worse. I'm on PT HD ultimate (latest) running High Sierra 10.13.6 S3 is connected by Ethernet 1. Not sure why Wi-Fi would come into play here but it is definitely a factor. |
Re: Network Error
This could possibly be caused by something changing your network during use. EUCON doesnt like changes to networks whilst running. Unfortunatly the list of things that causes network blips is quite long. Is it possible to disable WiFi for a while and see if the problem goes away ?
Re: Network Error
Things definitely improve when I turn off Wi-Fi but unfortunately, WiFi is my only option at this point. I can run a hard wire to my router for various logistical reasons and there are several plug-ins that insist on calling home during sessions so I need to have internet enabled.
Is there a way to have some kind of direct IP/proxy connection that is stable? |
Re: Network Error
OK...so thats good news (sort of) I suspect that the WiFi is re-connecting occasionally in the back ground, are you close to the router?
Just to rule out things can you connect EUCON to the other Ethernet port ? Also what order are the network ports in the prefs |
Re: Network Error
OK. I'll try Port 2 and see what happens.
Unfortunately, I"m not all that close to the router, otherwise, I'd run the internet via Ethernet hard wire. The network ports had Wi-Fi first followed by Ethernet. I've just switched them to show Ethernet first on the list. I'll see if these changes help. A support tech at Avid said that this was a known bug with High Sierra and Eucon. Do you know if this kind of issue is being addressed with the next Eucon update? Thanks Eddie. |
Re: Network Error
I'm not aware of that bug ;-/ 18.3 should be OK on that.
Network clock error | yop22 | Post - Surround - Video | 0 | 11-20-2014 01:57 PM |
Network Error when switching on MC Control, Mix and Transport | dkean | Artist Series | 6 | 03-01-2013 11:10 PM |
Network error: Pro Tools in used by another user ??? | joeytpg | Pro Tools M-Powered (Mac) | 1 | 07-24-2007 07:26 AM |
Error - Unmapped Network Volumes | lovett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-25-2006 10:14 PM |
