Old 04-17-2021, 11:28 PM
guitarist9891 guitarist9891 is offline
Default Artist Mix fine fader resolution
Hello,
When I hold down the command key and adjust the fader in pt mixer with my mouse it moves fader by 0.1 db increments. Is there a way to achieve the same when adjusting the fader on the artist mix? (Or the new 8 fader pack from avid). Holding the command key does not affect the artist mix.
Thanks in advance!
Old 04-19-2021, 01:11 PM
EddieJones's Avatar
Default Re: Artist Mix fine fader resolution
The Fader is physical so technically not possible, otherwise the fader would not be in the correct position. Fine mode is the Control key on the S1 but its for knobs not faders. Fader fine mode on the Control App is touch the fader then touch a second finger on the screen next to the fader.
Old 04-19-2021, 05:42 PM
Makes sense thanks. It would be nice if the motorized fader changed resolution in fine fader mode and then bounced to its correct relative position after the fine mode has been deactivated.
Old 04-27-2021, 10:19 PM
Mark Ziebarth Mark Ziebarth is offline
Usually faders have 1024 steps. That’s finer than what I can do with my hands. If I need 0,1 db precision I use the mouse but that’s not very often.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 07-11-2021, 10:51 AM
Suad Cokljat's Avatar
Suad Cokljat Suad Cokljat is offline
This is great idea. Cheers!
S
Command 8 fader resolution lululu ProControl, Control|24, Command|8 7 10-22-2009 02:37 AM
Command 8 fader resolution? turnstile ProControl, Control|24, Command|8 6 02-24-2005 02:36 PM
Fader resolution in PT johnnyv Pro Tools TDM Systems (Mac) 9 05-14-2001 05:57 AM
C24 Fader Resolution fdc ProControl, Control|24, Command|8 9 03-12-2001 12:53 AM
Fine (fader) Resolution on Motor Mix Bill Esses Pro Tools TDM Systems (Mac) 0 07-30-2000 01:06 PM
