the QuickTime wrapper failed to load
Hello,
I am getting this error message when I try to import a .mp4 from an editor I'm working with. This files opens fine straight into QuickTime and other .mp4s open fine in the same session. "the QuickTime wrapper failed to load" Has anyone had experience with this error? I haven’t found a workaround yet. File Duration: 25:48 File Size: 408 MB Resolution: 1280X720 Codecs: HEVC, AAC
iMac (Retina 5K, 27-inch, Late 2015) 32 GB 1867 MHz DDR3 3.2 GHz Intel Core i5 High Sierra 10.13.6 ProTools 2019.12.0 Artist mix/Control Axiom 48 G-Raid External Drive ...Nintendo Switch |
Re: the QuickTime wrapper failed to load
99% of the time, I convert any AVC and/or H.264 file I get into DNx or ProRes for compatibility and smooth performance in Pro Tools. Lots of tools out there to do this, I use Adobe Media Encoder, but there are free ones out there as well:
https://avid.secure.force.com/pkb/ar...e-Type-Support
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
Thank you reichman,
I did covert the video which did solve the issue, I used quicktime as a fast export this time, but you bring up a good point that I may just add conversion in Media Encoder into my workflow. Thanks for the tips
the QuickTime wrapper plug-in failed to load | Heilos4 | Pro Tools 2020 | 0 | 01-27-2021 03:52 PM |
falcon failed to load because it is not a valid 64 bit plugin | fourthtunz | Pro Tools 2019 | 1 | 07-09-2019 07:36 AM |
Quicktime plugin Failed to Load Error | DonaldM | Post - Surround - Video | 1 | 05-07-2018 12:21 PM |
PTHD 12: Quicking Wrapper Plug-in Failed to Load | catsynth | Pro Tools 12 | 0 | 04-23-2017 01:46 PM |
Quicktime wrapper error when importing Quicktime file | QuacksMeUp | Post - Surround - Video | 6 | 11-04-2015 05:07 PM |
