Old 06-20-2004, 05:01 PM
surchur surchur is offline
Default how do you activate the shortcut commands
I bought the digidesign keyboard, but alot of the commands are not working in the standard mode and I know there is a way to activate the stardard protools commands. the keyboard did not even come with a chart. you would think for 250.00 they would give me at least a little booklet or chart on using the keyboard can someone direct me?
Old 06-25-2004, 07:17 AM
dbto dbto is offline
Default Re: how do you activate the shortcut commands
You have to activate Alpha Mode in PT. Do this by clicking (and subsequently lighting up) the little button that says "a...z" which is located under the zoom presets and stuff, in the row just under the top section of the edit window. This button should be right above the first track's sends, etc... This is what I do to activate keyboard shortcuts on a standard keyboard. I'm pretty sure this is what you need to do, but hope it helps.
db
Old 06-25-2004, 08:20 AM
davetron5000 davetron5000 is offline
Gotta love the Digidesign "shortcuts" that involve the mouse.
I think you can activate those shortcuts by holding down a modifier instead of having to select the "a..z" button. I can't recall what it is, but if you look at the first page of the Keyboard Reference card (a pdf in the documentation folder) it should say what it is.
MacBook Pro Core Duo 1.83
2 Gig RAM
OS X 10.4.8
002R/PTLE 7.3.1
Old 06-25-2004, 08:42 AM
You only have to select the "a..z" button once (it lights up), then your keyboard commands always work. On my system, it seems to hold as 'active' whenever I start a new session or whatever. You do not need to click this button each time you want to use a shortcut, only once to activate the feature.
Old 06-25-2004, 09:25 AM
thanks to all of you I use a lab top there seem to be some differences, but I bought the keyboard from pro tools and a external mouse. and now I'll start making flash cards and carry them around to learn this stuff.
Old 06-25-2004, 09:45 AM
Luzer Luzer is offline
If u dont sit on a PT 5.X LE system, then u dont have the a...z knob, like me (
Activate inactive plugins shortcut? lownotesinc Pro Tools TDM Systems (Mac) 6 02-11-2020 04:21 PM
Shortcut commands not working E-Lister Windows 4 02-24-2012 11:09 AM
Shortcut/Key commands gone Wisur Pro Tools TDM Systems (Win) 0 12-25-2006 09:19 AM
Shortcut commands LUEDEMANN Tips & Tricks 4 12-01-2004 12:36 AM
Shortcut commands PlainJoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-10-2004 03:44 PM
