#31
Re: Video Card - Mac Pro High Sierra & Native
What exactly are the power specifics of the 5,1 Mac Pro and HDX card? It seems there is differing information about whether or not the 6 pin connectors in the Mac Pro are 75w each or 150w each... and I can't find any mention of what the HDX draws in the slightest.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
#32
I have no hard evidence, only more forums of more people getting confused about wattage draw. I'm going on what Mike Thorntorn of Pro Tools expert did with advice from Create Pro (here in the UK) and right now it is working a charm.
James Welch Recording Engineer | Producer Masterlink Productions Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire) macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24 |
#33
Yeah, it seems like a bit of a minefield out there in this regard. Just to clarify, when you say you spliced into the PCIe AUX power for your HDX card, would using a simple 6-pin mini-PCIe Aux 'Y' cable achieve the same thing? I have a Mac Edition GTX 680 sitting here that uses 60w less power than your 280x, so the same solution should work fine.
#34
See this post for details: http://duc.avid.com/showpost.php?p=2491563&postcount=34
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. Last edited by off the wall; 12-03-2018 at 03:03 PM. |
#35
Interesting. I am currently using all 4 hard drive slots, but is there any reason why I couldn't use the 5.25" bay sata connectors to do this?
#36
You just have to have the right adapter cables and squeeze the wiring through the case to get to the top section.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
#37
Definitely can use the optical bay power for the HDX card. I’ve since discovered that if you temporarily slide the power supply out, its very easy to get the power cable out of the optical bay to the HDX card. I may redo my setup the next tome I have the Mac Pro out of the rack and apart.
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
#38
I assume Avid make a standard 6-pin to HDX harness that I should get my hands on rather than reinventing the wheel?
#39
#40
Mine didn't, but it was a reverb purchase. Good to know the appropriate cables exist out there. Thanks everyone.
MAC PRO High Sierra & PTHD 2018 can't recognized PCIe Native card | Sutee Sangsareechon | Pro Tools 2018 | 1 | 05-11-2019 04:48 PM |
S6L AVB with OS X High Sierra | brinnbacka | VENUE Live Sound Systems | 3 | 10-20-2018 12:52 AM |
Question: Sierra or High Sierra for PTHD 2018.3? | johnnyv | Pro Tools 2018 | 25 | 03-18-2018 08:30 PM |
High Sample rates with Native HD card | Media Man | Windows | 6 | 02-27-2017 11:48 AM |
HD Native card physically generates high pitch whine or squeal | mlange | Pro Tools HDX & HD Native Systems (Win) | 6 | 03-15-2012 02:59 AM |
