Old 12-17-2019, 07:36 PM
robertg robertg is offline
Default Eucon 19.12 new logic bug - shift button
Eddie, first I want to say fantastic work on the new Avid control app. It's fast, responsive and it looks good, big criteria for me.
Some things don't work right in Logic X, but I wanted to point this bug out:
The shift button doesn't latch anymore when it's held down. It does latch when both shift buttons on a surface are pushed, however it's stuck in this mode with no way out of it except to restart Eucon.
thanks
Old 12-17-2019, 08:09 PM
sjgam sjgam is offline
Default Re: Eucon 19.12 new logic bug - shift button
thanks
I am getting same thing on Logic X with Dock and Artist Mix. Worked in previous release.
Old 12-18-2019, 01:48 PM
EddieJones's Avatar
Have you tried the checkbox in EuControl/Preferences Miscellaneous ?
Old 12-21-2019, 12:55 PM
tmuzik tmuzik is offline
I found that opening EuControl Settings and ticking then unticking the "Latching Shift". allows you to tap the shift on the surface which makes it start to respond again.
I just leave the latch ticked for now - which works for me for the most part - I do a lot of one hand moves on the surfaces anyhow and holding the shift + some function was sometimes quite a finger stretch.
Who is John Galt?
Old 12-21-2019, 01:36 PM
Eddie, toggling that checkbox does clear the shift back to normal. Can we get the old behavior back though? To un-latch shift just by pressing it again, not have to open the preferences.
thanks
Old 12-21-2019, 01:38 PM
EddieJones's Avatar
It should work the old way with the pref changed, are you saying it doesn't?
Sent from my HMA-L29 using Tapatalk
Old 12-21-2019, 01:41 PM
thanks
Kinda, the latching shift pref causes it to stay latched immediately when you press it. Used to have to hold it a bit. Not a big deal at all, this is workable, it does release when you let go which is the main thing. I wasn't aware of the preference setting before
Eucon 3.1 bug with McMix: Shift-Fader doesn't work DhyanMikael Artist Series 5 12-24-2013 04:50 AM
Eucon Ver.3 software & Control Monitor button workinstiff Artist Series 2 09-07-2013 11:12 AM
FR: Independent shift button... JR Fountain Artist Series 3 12-05-2011 08:17 AM
FaderPort glitch -- shift button causes havoc Even Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-19-2008 07:44 AM
Time Shift "Preview Button" a2zproductions Pro Tools TDM Systems (Win) 0 09-26-2006 10:27 AM
