Old 02-03-2019, 04:11 PM
epu epu is offline
Default No Input Signal (Receiving It In Logic, But Not PT)
Hey guys. Long time.
I am running PT 12.5.2. on my Macbook Pro 2014.
I am not getting any input signal whatsoever. Regardless if I use the built in microphone or my Komplete Audio 6 Interface from Native Instruments which worked without a hitch until this morning.
I upgraded to Mojave but up until about a week ago, everything was running fine.
I can record without issue into Logic. I can receive and record anything from the audio input.
Any ideas why I may not be getting an audio signal into PT anymore. Software Synths work just fine in PT. Because I can't even get something when the Mac's Built In I/O is used as the interface, it leads me to believe it is something with PT as opposed to the interface(s) I am using.
Macbook Pro 15" (Mid 2014)
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 02-03-2019, 04:18 PM
BScout BScout is offline
Default Re: No Input Signal (Receiving It In Logic, But Not PT)
http://avid.force.com/pkb/articles/e...nput-on-Mojave
Been asked (and answered) before
Old 02-03-2019, 04:26 PM
epu epu is offline
Hi BSCOUT. Thanks for the answer. I thought this applied to the built in microphone only.
Thanks again!
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Pro Tools suddenly stops receiving MIDI signal Robusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-17-2016 09:44 AM
Issue receiving audio signal (new forum user) Joejoe1414 macOS 6 10-24-2014 03:01 PM
Aux not receiving bus signal [Solved] arturoinletto Pro Tools 11 2 01-14-2014 07:34 PM
Not receiving much signal from audio on faders remusjacobs macOS 0 02-17-2012 07:34 AM
MIDI PT8 LE not receiving input signal Recloose MIDI 3 09-02-2009 07:03 PM
