gridlines in slip mode
Hi, the gridlines disappear when I go into slip mode in the midi editor....but it only happens in some sessions. Does anyone know how to fix this? Cheers
Re: gridlines in slip mode
I believe it's a session setting. At the top, where it says "Grid" and "Nudge", click on the button/word "Grid". You can then change the grid settings while you're in other modes.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Thanks for you post but that didn't work. I have seen that there is an issue with this.Any input would be appreciated.
Try this...
Go into slip mode, then click once on the ruler format in the upper left of the edit window. I.E. if you are in Bars/Beats, click once on the Bars/Beats box just to the left of the rulers in the edit window. This should toggle the gridlines on and off. If that's not it, then I'm not sure what it might be. But I have definitely been bit by this one a couple of times.
Scott Gatteño |
When you're in slip mode the grid will adjust to your timecode settings. If you set it to bars/beats it will show the grid like you want to. If you have it set to min/sec the grid will show the seconds, etc. So; Change the counter to bars/beats and you'll be good :) |
Thanks so much, Vincent.
Makes sense! |
Errors in Slip mode for groups | Ty Ford | macOS | 3 | 03-14-2012 05:07 PM |
SLIP mode on Pro Tools SE | beatrizfons10 | Pro Tools SE and Essential (Win) | 6 | 12-17-2011 09:38 AM |
Grid Lines in Slip Mode 9.0.5? | anackman | macOS | 3 | 09-15-2011 03:24 PM |
Slip mode but no overlap | dagamba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-14-2010 02:56 AM |
Grid mode, shuffle mode, spot mode and slip mode. | RogTaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-24-2010 10:30 AM |
