Old 06-05-2011, 04:35 AM
rockposer rockposer is offline
Default Can't get my pro tools le 8.05 working properly
Hi. I've been a PT LE user for a long time both on a macbook and a desktop Phenom XII with windows 7 64 ultimate. Now I went and bought myself a Fujitsu AH-530 with following specifications:
SiSoftware Sandra
Computer
Model : Fujitsu LIFEBOOK AH530/HD6
Workgroup : WORKGROUP
Host Name : Protools-Dator
User : Protools
Processor
Model : Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz
Speed : 2.8GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 2 Unit(s)
Type : Mobile, Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing
Computer
Mainboard : Fujitsu FJNBB0B
BIOS : FUJITSU // Phoenix Technologies Ltd. Version 1.11 11/22/2010
Bus(es) : X-Bus PCI PCIe IMB PCMCIA USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3GB DDR3 SO-DIMM
Chipset
Model : Fujitsu Core (Auburndale/Havendale) DRAM Controller
Front Side Bus Speed : 133MHz
Total Memory : 4GB DDR3 SO-DIMM
Channels : 1
Memory Bus Speed : 2x 532MHz (1GHz)
Memory Module(s)
Memory Module : Hynix (Hyundai) HMT351S6BFR8C-H9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : AMD Radeon HD 6500M/5600/5700 Series (400 SM5.0 500MHz, 1GB DDR3 1.6GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL Processor : AMD Radeon HD 6500M/5600/5700 Series (400SP 5C 500MHz, 512MB DDR3 1.6GHz 128-bit)
Compute Shader Processor : AMD Radeon HD 6500M/5600/5700 Series (400SP 500MHz, 1GB DDR3 1.6GHz 128-bit)
STREAM Processor : AMD Radeon HD 6500M/5600/5700 Series (400SP 5C 500MHz, 1GB DDR3 1.6GHz 128-bit)
Storage Devices
Seagate ST9500325AS (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 466GB (C:) (D:)
TSSTcorp CDDVDW TS-L633B (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Hard Disk (D:) : 146GB (NTFS) @ Seagate ST9500325AS (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
Hard Disk (C:) : 319GB (NTFS) @ Seagate ST9500325AS (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
Optical Drive (E:) : N/A @ TSSTcorp CDDVDW TS-L633B (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Fujitsu HM55 LPC Interface Controller
LPC Legacy Controller 1 : Winbond W83687THF
Audio Device : Fujitsu P55/PM55/3400 High Definition Audio
Audio Codec : Realtek Semi High Definition Audio
Audio Device : Fujitsu Redwood HDMI Audio [Radeon HD 5600 Series]
Audio Codec : ATI (AMD) HDMI Audio
Disk Controller : Fujitsu P55/PM55/3400 4 port SATA AHCI Controller
USB Controller 1 : Fujitsu P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : Fujitsu P55/PM55/3400 USB2 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Wireless Adapter : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), TKIP, 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 96%
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x86
Windows Experience Index
Current System : 5.9
I tried installing windows 7 64 ultimate but it didn't work out very good with pro tools so I switched for the últimate 32 bit instead. Anyway the problem I have is that on my old desktop Phenom X2 I could run my projects with 128 latency but now on a really small project (3 channels, 1 vacuum bass synth, 2 d-verb and 2 digidesign compressors) I can't get it to run from my internal disk which I could on my desktop. Would you guys recommend me using an external usb-2 disk (my laptop doesn't have firewire or usb-3) or how would you recommend me to fix this? I've done everything that Avid recommends when it comes to tweaking windows and have no other programs running. Thanks for taking the time to reading my post!
/Johan
Old 06-05-2011, 12:27 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Can't get my pro tools le 8.05 working properly
Couple of problems:
1) Your system disk is only 5,400 RPM. Pro Tools requires a physically separate hard drive - not a partition - and the drive needs to be a minimum of 7,200 RPM. The Western Digital Caviar BLACK 64 mb cache drives are a forum favorite right now. And yes, you can - and Avid recommends - using a USB external with Windows 7.
2) You have one 4 gb stick of DDR3 RAM listed. The only way that is going to run at DDR3 speed that I'm aware of is if there are 3 sticks of RAM. Not sure what speed your RAM is running at with just one stick.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Digidesign Midi IO not working properly in Pro Tools 11.1 HD on Maverick! bigknowsal Pro Tools 11 1 01-05-2014 07:39 AM
Signal from Profire 2626 to pro tools isn't working properly beasleymusic Pro Tools M-Powered (Win) 2 08-21-2010 08:09 PM
Pro Tools M-Powered at 96khz: is it working properly? creator Pro Tools M-Powered (Win) 0 12-01-2007 11:44 AM
TC/E not working properly. twigstickley Pro Tools TDM Systems (Mac) 2 03-22-2005 10:12 AM
PT not working properly chainboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-21-2004 01:11 PM
