Old 06-27-2017, 09:24 PM
Wawili_Sound Wawili_Sound is offline
Default Trim audio clip to next audio region.
Hi
I have been looking for a shortcut to butt up a trim to the next audio clip whether that be left or right. Basiclly I dont want to be zooming into sample level to trim audio clips to butt up perfectly. Does anyone know if there is a shortcut.
Please and thank you. I have looked through shortcuts but cant find it.
WIN10 12.6 HD Native, Omni, BlackLion XB192
Old 06-27-2017, 11:48 PM
Stig Eliassen's Avatar
Default Re: Trim audio clip to next audio region.
It's Ctrl+trim on Mac, so I assume Start+trim on PC.
Old 06-28-2017, 02:58 AM
Ok I will try that, thanks
Old 06-28-2017, 08:16 AM
john1192 john1192 is offline
on the MAC - you mean Control "A" or "S" (trim start, trim end respectively) ??
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-28-2017, 08:57 AM
No. I mean hold down Ctrl, then click'n'drag to trim the clip up to the previous/next clip in the timeline.
Old 06-28-2017, 08:59 AM
hi Stig, yes, i see it now .. Control Stops the Trimming Clip from going past the NExt Clips Start point ..
good to now .. thank you !!!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-28-2017, 09:05 AM
No problem
Old 06-28-2017, 11:49 AM
joachim's Avatar
joachim joachim is offline
Another way, extent/trim the clip to the left up to the previous clip :
1. select clip ,
2. Ctrl-Shift-Tab (extend selection to the left) (Win) ,
3. Edit - Trim Clip - Start to fill Selection.
Makes sense, if commands 2. and 3. are scripted (e.g with Autohotkey, as in my case) and assigned to a personal shortcut or a programmable second keyboard.
I use 3 : fill clip to the left , fill clip to the right, fill clip to left and right.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Importing audio extends the audio clip (I checked sample rate) Lonus Pro Tools 11 1 01-04-2017 05:15 PM
Audio Suite "No Audio Selected" to reverse clip ReynaldoPena Windows 1 11-24-2012 08:21 PM
SLide audio inside audio region JuanM Tips & Tricks 2 03-22-2007 07:19 PM
trim an audio waveform? tritonkorg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-10-2005 11:48 PM
Can you trim while seeing audio? Corey Shay Tips & Tricks 0 12-21-1999 08:22 PM
