#31
I feel for you. And I too am ready to throw the towel in. In fact I want compensation for all the lost hours of work. ProTools is the centre piece of our studios therefore it must run right. If it has a problem with 3rd party software i.e plugins then there should be messages and work arounds such as warnings & such....Still I supose I could sell my prized synths and buy a HDX system but whos to say thats stable too?. It really is getting crazy... I sold my Sadie system to get into ProTools now im thinking oh no!
"We are just button makers we are not button pushes" Zsarbomba 2013 |
#32
![]() Quote:
Each daw has it's own quirks, some more than others, and some are really more finicky about what they need. Pro tools is a different daw altogether from the lot of them in the sense that it actually runs real time processing in line with the CPU, compared to the others that run by delayed packet instructions (or something similar.. I'm tired :P) That real time processing actually requires a lot more from the computer than the others, but at the same time it gives a lot more too. So again, take a break, breath in breath out.. wax in wax out.. humm and do what ever you need to calm down, because right now you're fueling yourself with rage for something that Avid is not responsible. 1 sales of the interface (tascam), 2 computer that does not meet required specs (as in two HDD and yes it could be related to the crash you were having). So once we've all got some hours of sleep, level headed.. a few pint of coffee.. ![]() But if you're just bent on keeping venting on this forum and saying you hate this and that company comparing it to an other piece of software that might look like it's doing the same thing, but it's not at it's core, then you can always return what you bought and move on. The choice is yours. Until then I truly hope you have a good night. ![]()
Manny. |
#33
![]() Quote:
Now if you have a specific problem with your system, you know the drill. Start your own thread with all the information needed, and someone will probably try to help you. I want you also to think on what I wrote in my previous post and I'll add to that, the amount of people that actually post bug reports or technical glitch with their setup is minimal compared to the number of people that actually use a software (all software intended here not speaking of Pro tools specifically) without problems. It's those that usually have problems that you will see post.. because they are looking for a solution, while those that do not have a problem, rarely thinks about making a post about how good what they are using is.
Manny. |
#34
If I can add just a thought to Manny's good words:
I have be running Pro Tools studios for many years. I don’t come here with problems or complaints. I just come here to help others. If my systems can run day in and day out, so can yours. We simply need to find out what you may have missed in Hardware, setup, and Plug-in choices. And there might even be a little pilot error thrown in as well. We are here to help. A good Pro Tools setup can require a fair amount of patience, but it's worth it.
~ tom thomas Formerly hobotom Pro Tools Ultimate 2019.10 HDX HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
#35
I too had some problems installing Pro Tools with my Tascam Interface (I use a US-1800)
But I got it working with some help from old post from this forum and some coincidence. I had to disable mutliple Accounts on my Windows System, so that the account I am using has admin rights and disable all antivirus software while installing Pro Tools. The Problem with the Tascam driver seems to be that on a windows system it can't set the buffer size and you can't set it manually to the right size. The solution for me was to select another device for the system sound, so the Tascam interface is not in use by any other application and install Asio4All which addresses the Tascam (I still got all the input and output capabilities). I still have to manually select the driver when Pro Tools is starting (by pressing "n" continously). I think the key is to install Pro Tools correctly which is quite counter intuitive on windows at least (I have some colleagues who use mac systems and the seem to have no problems whatsoever) But I still think the Avid support (with exeption to this forum which as I said did the trick for me) is quite unorganized and unhelpful. I hope that provides some starting points for you. |
#36
If I may lighten the thread by interjecting a bit of humor...
http://duc.avid.com/showthread.php?t...ght=reputation [OPINION] My own observation...people who post like the OP did here have a "personality type" that may not allow them to successfully use Pro Tools. Picking up on the Ferrari analogy, someone who just got their driver's license is probably not going to be able to properly drive such a high performance vehicle. Doing so requires far more knowledge than just where to put the key in it. So it is with Pro Tools...in general, you can't just pop in a DVD, connect a cable, and go. Unless you're me (see post I linked to ![]() And you aren't going to get good results in 30 seconds...you have to be willing to take the time required to get the results you want. There simply are no shortcuts. Think of using Pro Tools as being like becoming a Navy Seal...it's a b*tch to get in, but once you do you get to play with some really cool toys and do amazing stuff. Regarding the "personality types" and posts I mentioned earlier, I'm very slightly bipolar so I too have made some "ranting" posts from time to time. But generally I manage to keep my feelings in check and just post all of the information needed to solve my problem (if a solution is possible). I've found that I generally get better results from the "cool, calm, and collected" posts. In fact, once I get things in check to make a "good" post, I'm often able to take a better look at the situation, and I'm freqently able to resolve the issue without assistance. [/OPINION] So, while all I personally have to offer is a "good luck", I hope you are able to get things going. Pro Tools is amazing, but it is a professional tool, and you have to be willing to deal with it as such...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while... ![]() Just rockin'...what more is there? Bill in Pittsburgh |
#37
And,
Have you in fact contacted your salesman for help on this yet? Did he explain to you that you are not running an AVID qualified computer? This really is his responsibility. Ask him to make it right for you. Again, best of luck to you wherever your decisions may lead you. http://avid.force.com/pkb/articles/e...315?popup=true
#38
I'm butting in here but, all the posts by Avid/Pro Tools Moderators and supporters could have been stated simply as in, "If you can't run with the big dogs, stay under the porch!" This may have hurt the guys feelings a little but it explains the fact simply and to the point! Avid should have a disclaimer with all their software in bold print, READ THIS BEFORE YOU PURCHASE! If you don't meet the qualifications or lack any of the computer skills or knowledge required, or, if any of your other software//hardware is not compatible with this version of Pro Tools
#39
PT is a professional level program and that means complexity and hardware requirements.
Also, right now is very old picky code that takes some work to get running. Most importantly, Avid has a free 30 day trial offer.
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra |
#40
And this is what the salesmen should be pointing out. Sell them a iLok. Point them towards the trial. And say "try this- see how you like it and how it works with your hardware"
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
PTHD 9.0.5 Crashes on "Quit Pro Tools", Every Time. | SmokinBaldMonkey | Pro Tools TDM Systems (Mac) | 4 | 06-04-2012 05:34 PM |
PT 10.0.1 crashes on quit | BGMusic | macOS | 0 | 03-07-2012 01:02 PM |
Pro Tools 9 Crashes When Selecting Audio Interface | siraltus | Pro Tools 9 | 65 | 03-26-2011 09:06 PM |
Rewire crashes PT8 on quit | tonwurm | Pro Tools TDM Systems (Mac) | 7 | 05-15-2009 08:18 AM |
One reason why Pro Tools 8 crashes at Quit | Arvid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-10-2009 12:03 PM |
