Old 11-18-2004, 01:45 PM
willbgoode willbgoode is offline
Default help with pop repair
i have a couple of nasty vocal pops on a track 'telePathic'
i know there are ways of redrawing them out
can some one explain how?
thanks
Old 11-18-2004, 05:05 PM
KingFish KingFish is offline
Default Re: help with pop repair
Sometimes in "volume Mode" I'll zoom in on the pop, and yank it down, other times, i'll loop the pop, insert an EQ, raise a band 5 or 10 DB, and sweep to find the main resonance of the pop. and pull it down 5db or more.
Then I'll draw automate the Bypass on the EQ, remaining bypassed EXCEPT for the pops on the track.
Good Luck
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 11-18-2004, 06:03 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
The velocity of the air popping the mic is greater than the sound wave of the "P". Therefore the popping sound is earlier than the "P"
You can cut the pop out and create a fast fade into the "P" . Drawing out with a pencil tool will leave a residual sound.
IMDB
Old 11-18-2004, 06:08 PM
spigots spigots is offline
I use a Hi-pass at around 185 really steep and Audiosuite the P, then trim and cross-fade to taste. If it's really bad, Ill sometimes drop the volume as well. If you save a preset in your favorite EQ, it becomes an easy task.
Frank
Old 11-18-2004, 08:39 PM
talco talco is offline
I use Spigots approach. Works great. Filterbank does a nice job of it. The highpass filter at 12db/octave and sometimes a dip with the lo shelf as well.
003 repair Bender Pro Tools 10 6 11-09-2012 03:06 PM
003 Repair Pierres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-23-2011 04:50 AM
AKG 414 repair F.J. General Discussion 3 10-24-2005 11:54 AM
mic repair in NYC? wolfhound Pro Tools TDM Systems (Mac) 4 08-08-2002 04:09 PM
Mic Repair / NYC andyo General Discussion 2 03-03-2002 01:34 PM
