Old 06-24-2018, 03:10 AM
Emi's Avatar
Emi Emi is offline
Default Re: PT 12 2018.4 w/ OSX 10.13.5
Everything working smooth here.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 06-24-2018, 04:59 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Smooth n stable here.
<<testing in sig
Old 06-29-2018, 07:56 AM
Gemylon's Avatar
Gemylon Gemylon is offline
Just did the update as well.
Working great !
MacBook Pro M2 Max / Pro Tools 2024.3.1 / MetricHalo ULN-8 MKIV / AVID Console C|24 / UA 6176 / Neumann U67 / Oram S200 / UAD Octos /
Old 07-01-2018, 07:39 AM
TheEdster75 TheEdster75 is offline
I have a question for you guys.. I really do need to upgrade. Right now I am on Pro Tools 11 in Yosemite 10.10.2, if I upgrade to High Sierra 10.13.5, which is my ONLY option, will that wipe out all my installs from Yosemite? Will I have to reinstall everything if I upgrade?
Edward Fenley
"Either learn to endure, or hire a bodyguard." ~ Bruce Lee
Old 07-01-2018, 09:07 AM
jjnssn jjnssn is offline
With this significant an upgrade, I have learned to install from scratch. I believe Sierra introduced AFP, so you may have to think through that choice. If you create an image/backup you can recover from it, then try the update method, (deleting all pro tools cache and preferences, etc....) and see if it works, most of the time it has worked for me, however I was not skipping versions. I don’t believe I had reinstalled from sierra to high Sierra.
  #16
Old 07-01-2018, 11:36 AM
BScout BScout is offline
Won't have to reinstall. Your installs aren't wiped.
Still a good idea to check and upgrade installs for any hardware drivers (like audio cards)
If you've ever downloaded other macOS versions (even if you haven't installed) in your Apple App Store account, you can still get to those mac versions. Or if you have a friend with the install image. I now make it a point to "update" every macOS version but then don't run the installer so I can get the macOS version when/if it gets qualified by Avid.
High Sierra (not Sierra) introduced/forced APFS on users. All flash/SSD drives will automatically be converted to APFS during the install of High Sierra.
  #17
Old 07-01-2018, 02:54 PM
Only drive I have that’s SSD is my drive that has my OS and program installs. My samples and sessions are all on external HD’s. Everything backed up on Backblaze. Except the samples drive. It kept self ejecting..
So will this APFS effect my installs? What is AFPS anyway?
Edward Fenley
  #18
Old 07-01-2018, 10:43 PM
adam_w1 adam_w1 is offline
so the 10.13.5 update has fixed the issues that were happening with 10.13.4 + PT?
  #19
Old 07-02-2018, 08:50 AM
685 685 is offline
Same question I had.
What type of sessions are these guys testing with?
  #20
Old 07-02-2018, 11:26 AM
High Sierra will convert your macOS hard drive to APFS format. APFS is a file system type.
https://en.wikipedia.org/wiki/Apple_File_System
It won't affect your installs -- your installs will continue to work. However, if you need to go back, you will need wipe your hard drive and put it back to Mac OS Extended format. So make a copy of your boot drive before doing the update to High Sierra.
PT 2018 do I need more RAM? shtik Pro Tools 2018 4 03-26-2018 01:13 AM
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 04:41 PM
Reverting from 2018.3 to 2018.1 jamesleonard Pro Tools 2018 11 03-12-2018 05:21 AM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
