Separate headphone mix with Eleven Rack
hi guys
I'm trying to set up a separate headphone mix via a bus or aux send in my sessions. Using the Eleven Rack I have no other options for routing the analog output signal besides main out l and r which is already assigned to my monitors (KRK rokit 6's). Do I have to use a headphone amplifier or some kind of splitter after the main outs of the 11 rack? I currently have to turn the KRK's off every time I want to monitor purely from cans as I have no way of controlling individual levels. thanks in advance for your advice. |
Re: Separate headphone mix with Eleven Rack
If you use a splitter, you'll be able to run a second set of headphones, but it will still be the same main mix.
Your only other output option for a separate mix would be the digital outs. So you would need a headphone box with a Spidf input, and this new product has that and would probably be the cheapest option you could find: http://www.sweetwater.com/store/detail/HeadPod4/ |
Eleven Rack headphone out | Frankenbeats | Eleven Rack | 12 | 02-12-2013 09:17 PM |
Separate Headphone Mix for Drummer using Eleven Rack and PT9HD | sharchik | Pro Tools 9 | 11 | 08-21-2012 08:33 PM |
Eleven Rack headphone port versus MBOX and other interface headphone ports | World Spirit | Eleven Rack | 3 | 02-12-2012 11:34 PM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
Separate headphone mix out | rosindabow | ICON & C|24 | 0 | 11-10-2009 06:07 PM |
