Old 03-25-2023, 06:04 AM
tonyw7 tonyw7 is offline
Default PlayCell is just an empty black window [XUJAM-190]
Has anyone encountered a problem with playcell?
I installed PT latest update along with the both downloads of playcell via avid link.
When I insert playcell I get an empty black window.
All my other virtual instruments work fine after this update.
Mac pro 2013
Monterey latest update.
Old 03-25-2023, 07:11 AM
Ben Jenssen's Avatar
Default Re: playcell
Me too.
I'm guessing it has to do with ilok license missing. But then, we should be getting a ilok error, not a black window.
I have Groovecell and Synthcell licenses in ilok manager, I think they were just placed there when they came out, I activated synthcell back then, and it worked. It still works. I'm guessing it might be the same w/Playcell, and they just forgot to give us the licenses. Looked for anything on avid.com, without any luck.
Old 03-25-2023, 07:30 AM
I am sure Avid will fix this.
Thanks for the reply
Old 03-25-2023, 08:22 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
Mac pro 2013
Yes same issue here. Just a black box. I also suspect the lack of an iLok asset, like the other “cell” VIs have.
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 03-25-2023, 08:31 AM
its2loud its2loud is offline
FYI
PlayCell Palette Series
PlayCell graphics are not loading, and plugin presets are not writing. (XUJAM-190) This issue has been identified as an intermittent permissions issue and a fix is in the works which will be posted ASAP. Current workaround:
Delete the ~/Users/XXX/Documents/Pro Tools/Plug-In Settings/PlayCell folder
Launch PT and insert PlayCell, close
Reinstall Palette Series
Old 03-25-2023, 08:52 AM
Originally Posted by its2loud View Post
FYI
Thanks for the fix. Worked very nicely.
(Except the Palette installer has some strange behaviours; no installer window on launch, progress bar looks like it's freezing before completing. Looks a bit half-done.)
Old 03-25-2023, 08:56 AM
WorldStudios WorldStudios is offline
I have the same problem and will try the workaround.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
Old 03-25-2023, 09:42 AM
I got it to work with the workaround described above. It is not totally useless, but clearly aimed at getting some quick results with very limited resources and editing possibilities. A beginners toy, basically.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
Old 03-25-2023, 10:53 AM
smurfyou smurfyou is online now
So this isn't a modern Sample Cell?
~Will
Old 03-25-2023, 12:12 PM
albee1952 albee1952 is online now
Good question re SampleCell. Guessing the graphics issue is only on the Mac side as it works fine here on Windows 11
"PlayCell Palette install failed" trying to install PlayCell 2023.3 Dizzi45Z Virtual Instruments 3 03-28-2023 12:40 PM
black mixer-window. Meatbaker Windows 2 03-17-2014 12:35 PM
PT 10 all black edit window Mr609 Pro Tools 10 4 08-07-2013 12:57 PM
Waves plugs show an empty grey window, desperate andre tchmil Pro Tools TDM Systems (Mac) 0 02-06-2006 11:32 AM
