Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 08-03-2016, 07:54 PM
Midnite8 Midnite8 is offline
Default HD Native Thunderbolt
I picked up a Native interface that just had the 12v power adapter included. When I plug in the power adapter, I see no green LED light on. Does the HD Native require being plugged into thunderbolt or digilink cable to display the power LED?
Old 08-03-2016, 09:23 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Default Re: HD Native Thunderbolt
You actually don't use the power adapter. It's TB powered.
Old 08-04-2016, 03:47 AM
Southsidemusic's Avatar
And you need a Avid Interface and a HD license to use the thunderbolt box and its not a interface, just a pcie card in a box, do you have a Avid interface to connect?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 08-04-2016, 09:14 AM
So the green LED will not light up from the power adapter alone? What is the purpose of it then? From sweetwater it says:
Q: The Avid HD Native Thunderbolt interface has a power supply connector, but can it run on bus power?
A: Yes, the HD Native Thunderbolt interface will run off of Thunderbolt bus power. If you prefer, you could choose to run it off of an external power supply.
Old 08-04-2016, 09:59 AM
Audioartist Audioartist is offline
I had a TB port on a early 2011 MbP that did not supply power, a quite common problem I believe.
D-control ES 32 - Venue Profile 48x24 - S3L-X - Yamaha DM2000 - Artist mix and control - HD7 accel - HDX2 / Magma EB3T
HD native thunderbolt
PT10HD 10.3.8. - PT11HD 11.3.2
2xHD madi - 2xHD omni -
Old 08-04-2016, 10:22 AM
Yes the LED need a host computer Thunderbolt connection to go green. It's not just a "Power LED".
And to do anything at all, even to use the headphone output. You need...
1. Computer with compatible Thunderbolt connection.
2. Digilink interface connected.
3. Pro Tools installed with a Pro Tools HD license, standard Pro Tools is deliberately crippled so that it will not work with Digilink interfaces. (A setup may work with third party CoreAudio/ASIO compatible audio programs, where I'm being generous with "may" and "work").
If after connecting all this you still have problems start by running Digitest.
Old 08-04-2016, 10:26 AM
Ahh ok, so the LED is not a power LED, it is a connection LED. Makes sense! Thank you all!
Old 10-21-2016, 06:48 PM
syMPh syMPh is offline
If that's the case can i simply take that card out of my thunderbolt box and put it in my mac pro instead of buying a hdn card?
System Details
Old 10-21-2016, 07:23 PM
Nope.
Old 10-22-2016, 11:55 AM
YYR123's Avatar
YYR123 YYR123 is offline
Brand new HDN cards are $999
Go get another one and sell the one you have
Daniel
HD native thunderbolt with thunderbolt card on desktop PC? martthie_08 Pro Tools HDX & HD Native Systems (Win) 9 10-12-2016 10:26 PM
Trade hd native PCIe card for hd native thunderbolt card and cash? Brandonx1 Buy & Sell 8 03-22-2015 01:45 AM
HD native thunderbolt through Echo Express SE Thunderbolt Chassis hkj1 Pro Tools HDX & HD Native Systems (Mac) 1 11-06-2013 05:49 PM
Exchange HD Native PCI-e for HD native Thunderbolt sinewavz Buy & Sell 0 06-25-2013 08:26 AM
Anybody switched to a Macbook Pro Thunderbolt Native from Mac Pro Native? petesteen Pro Tools HDX & HD Native Systems (Mac) 7 11-17-2012 03:21 PM
