Old 06-23-2014, 10:31 AM
kbcarnut kbcarnut is offline
Default Need to transfer old Tech to New
Hi folks- I realize this is way "out of the box" and ancient history to many of you but.. I have a huge amount of audio archived on DAT and need to get it on to my computer for marketing to radio stations, etc.
My Sony PCM-R300 DAT machine worked well until I let it sit idle for several months. Now, when I insert a cassette the machine starts “searching,” going forward and backwards in 3 second cycles and then finally stops and indicates it's ready to play a track. However, if I push “play” the same back and forth searching starts again.
If I push the “record” button though, the machine will respond to the “play” button and start recording. I can listen to tracks recorded with my hand-held Sony “Walkman” DAT player and they sound fine. (using the Walkman to dub this material to my computer would be very clumsy)
I have a cleaning cassette and have run it twice with no good result.
kbcarnut/Baker Broadcasting
kbcarnut
Old 06-23-2014, 11:00 AM
Craig F Craig F is offline
Default Re: Need to transfer old Tech to New
it sounds like it needs more than a cleaning, probably a head adjustment
can you borrow one? or worst case rent one
Thank you,
Craig
Old 06-24-2014, 10:26 AM
I agree. I needed to do a bunch of transfers and just shopped locally and found a mint DA20 for $100
Does transfer of ownership transfer warranty? millhouse76 Eleven Rack 1 01-14-2012 11:44 AM
File transfer settings Mac transfer to Windows ? End Over End Windows 8 06-27-2011 06:32 PM
New tech support tools - Tech Support Folder DigiTechSupt Technical Alerts 0 08-07-2007 08:13 AM
OT - Mac to Pc Tech ? WizDoomBorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-28-2003 12:45 AM
Track Transfer won't transfer (time code problem) apetrocelli Pro Tools TDM Systems (Mac) 4 10-17-2000 01:49 AM
