How can PT show a Timecode offset ?
I'm working on some jingles for a radio station at the moment. Each jingle-theme has to be 40 sec, 1 min and 1'15. I'm using the same PT-session and just making 3 versions within a session. Question: How can I adjust a timecode offset so that PT shows me i.e. bar position 1|4|608 as 0:00 sec ? The only workaround I found so far was using LOGIC, which is synced via MTC on another Mac, and set the offset their, using "Enable Separate SMPTE View Offset" within Logic's synchronization window within the project settings. How can I enable a Min:Secs or Timecode offset directly within PT ?? Thx in advance for any tip
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Go to your bar beat potion and use the time operation move song start. Then switch to time code and set a marker at 40 secs. Then switch back to bar beat to compose.
Sent from my SGH-T769 using Tapatalk 2 |
You could also set your second time ruler to time code and leave the main ruler in beats and bars
Re: How can PT show a Timecode offset ?
Thx for the reply - but I don't wanna change the song start - I just want to have displayed *somewhere* the actual length of each version.
I.E. Bar Position 2,1,085 should be displayed as 0:00 sec for the first version. Then I would like to change the offset manually for the start point of next version. Next version will start at bar 24,2,914 and should be also displayed as 0:00. Thx again
Usual practice is to start them at a new minute, or minute + 30sec.
Or you could place some markers where you track needs to finish by.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
So I guess, it's simply not possible that PT is showing an offset timecode ?
Midi timecode offset | losrack | macOS | 1 | 07-08-2013 03:51 PM |
* key and timecode offset | CCash | Post - Surround - Video | 13 | 09-01-2011 01:24 PM |
Can I offset Bar/Beat & relative time from Timecode 4 QT? | Kelly Snook | Pro Tools TDM Systems (Mac) | 1 | 05-21-2007 07:26 AM |
PT 7.1cs7 bug? Timecode offset | audioposttvtwono | Post - Surround - Video | 5 | 06-13-2006 10:30 AM |
Timecode offset | russman | Tips & Tricks | 0 | 05-30-2001 10:08 AM |
