Old 08-15-2007, 08:21 AM
Mark Wheaton Mark Wheaton is offline
Default Frequent Hangs while activating inserts
I have had increasing issues where I work on a project with some VI's (RA, or Velvet for instance) and some SoundToys effects on Aux Tracks
When I go to re-open the session the next day it will hang on activating inserts, quite often the track named last during the hang, has no such VI or effect.
I have to force quit and then create a new session and import tracks. Usually I import all but the offending tracks and then once that is saved I can import the offending track. I have been suspecting the Soundtoys effects, Anyone have any ideas?
Old 08-15-2007, 08:51 AM
DigiTechSupt's Avatar
Default Re: Frequent Hangs while activating inserts
Which version of Pro Tools are you running? If it's 7.0 or higher, you absolutely, positively MUST make sure that all installed plug-ins (not just the ones being used in your sessions) are Pro Tools 7 compatible. Having just one incompatible plug-in installed can cause all sorts of bizarre problems.
Avid Audio Tech Support
Support FAQ
Old 08-15-2007, 08:29 PM
Yes my plugs are all vetted for 7.0 version. I have 7.3.1cs3 on OS X 10.4.9 My soundtoys are the latest update
System hangs when activating inserts CD Productions Pro Tools TDM Systems (Mac) 6 07-22-2014 01:16 PM
Pro Tools 9.0.2 freezing on activating inserts CatalystMusic macOS 0 05-23-2011 11:42 AM
Still getting frequent hangs with PT 8.0.1cs1 Phill Barrett Post - Surround - Video 0 11-16-2009 11:50 AM
Activating hardware inserts,help! speedyk5 Pro Tools TDM Systems (Mac) 1 05-20-2002 08:13 AM
Freezes on Activating Inserts essay Pro Tools TDM Systems (Mac) 2 06-13-2001 05:23 AM
