Using a stompbox on Vocals thru PT6.1?
I use a Boss Digital Delay/Reverb on vocals when I sing live, & I'd like to use it in my recording as well. What is the best way to hook it up to ProTools: Mic to Stompbox to Pre-Amp to Digi 002? Mic to Pre-Amp to Stompbox to Digi 002? Connect through an insert? Thanks |
Re: Using a stompbox on Vocals thru PT6.1?
i'd use it as an insert so that atleast your mic can be balanced(the pedal is 1/4" unbalanced i think)
ik zei nooit dat! |
I'd strongly suggest not using it at all, or maybe just monitoring your signal with (if you must because it's what you're used to). You certainly wouldn't want to track with it. The Digirack effects are worlds better than that mess. Just my opinion.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Aren't stomp boxes designed to be high impedance, going between guitar and amp? So if you use it at all, you will need to match the impedance going in and coming out. Big mess, I agree.
There got to be a way to make all 10 switches on the FCB1010 Stompbox. | Jd0g33 | Eleven Rack | 2 | 11-14-2011 10:46 PM |
FCB1010: How do you get all 10 pedals to stompbox mode? | Jd0g33 | Eleven Rack | 7 | 06-09-2011 02:50 PM |
Stompbox mode and the FCB1010 | vinceh | Eleven Rack | 0 | 01-31-2011 06:52 PM |
Anyone know a good distortion stompbox plugin? | Audioartist | VENUE Live Sound Systems | 8 | 05-18-2010 02:47 PM |
OT: Distortion stompbox reccomendations | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 01-23-2004 10:39 PM |
