Old 09-01-2016, 04:10 AM
aside aside is offline
Default Quartet "External Clock Source" error on PC
Hey guys,
Ok so this one is driving me crazy. I have a very simple setup, Pro Tools 12.5.2 running on a Windows 10 HP i7 laptop with a brand new AVID branded Quartet.
Done all the optimisations and have ensured Windows is using the onboard sound device, leaving the Quartet exclusively for Pro Tools.
Every few minutes I get the attached error message about the external clock source not operating correctly.
Any ideas? Short of a bad Quartet unit I'm stumped.
Any help much appreciated, cheers.
Old 09-01-2016, 08:32 AM
Southsidemusic's Avatar
Default Re: Quartet "External Clock Source" error on PC
Hi and Welcome to the Community
Have you tried trashing preferences and databases as thats what i would do first to see if anything old is interfering with the setup.
http://www.sweetwater.com/sweetcare/...s-preferences/
Let us know what happens if anything
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-01-2016, 02:43 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Originally Posted by aside View Post
Hey guys,
First question:
Is the clock source, set to "Quartet" in Set up: Session??
Second question:
Is the sample rate set in "Maestro 2" or whatever the Avid branded setup utility is called the same as your PT session??
IMDB
Old 09-01-2016, 07:48 PM
Thanks for the feedback.
Yep the setup is all fine, matching sample rates, Quartet selected in Pro Tools etc.
In a bid to randomly try stuff I disabled AVG antivirus and haven't had the error in a hour or two... weird. I'll report back!
Old 09-02-2016, 03:02 AM
ok - after disabling a few things, the error is much less frequent but still there. It seems like it's a processor thing, when too much is going on the clock error appears. Misleading, but life would be boring otherwise right
Old 09-02-2016, 03:08 PM
Heres an shot in the dark:
I have an HP laptop, it has both USB2 and USB3 ports.
I was having a communication issue with a cable used to interface with my car's ECU (ala Fast and Furious). The manufacturer told me to try it on a USB2, not USB3 port, and it solved the issue.
Look up in your manual, see which port is USB2, and verify, you're not on a USB3. Worth looking into.
Hope it helps
Otherwise, go here:
http://www.apogeedigital.com/support/contact-support
They answer in under 48 hours.
IMDB
Old 09-09-2016, 05:47 AM
Tried the USB thing, same - but thanks. Looks like it's a CPU overload thing, clock drops when the machine is working a little harder. Bummer
Old 09-10-2016, 09:19 AM
Have you returned to your vendor, and tested another unit?
IMDB
Old 09-10-2016, 03:05 PM
No I should do, but I contacted Apogee direct and they confirmed that error happens when the machine is working too hard. Still think I'll follow it up though. Thanks again!
Old 09-11-2016, 11:31 AM
My second system, 12.5.2 on a Mac Mini "Ivy Bridge" 2.6 GHz Intel "Core i7" (3720QM) Quad core, with the Apogee
branded Quartet.
Not one issue.
IMDB
v9.0.3 never opens with proper digi "clock source" glankrudolph Pro Tools 9 3 04-12-2013 09:45 AM
Audio clock problems.."Check clock source and sample rate.." Please help! beasleymusic Pro Tools M-Powered (Win) 1 08-03-2011 10:54 PM
Got some trouble with clock "mismatch of sync source" soundonthemoon Pro Tools TDM Systems (Mac) 0 09-21-2010 11:07 AM
Error: "Problem detected with audio clock. Check that your clock source and sample... mongo_man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 05-01-2010 06:08 AM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 03:40 PM
