Re: Share your 002 experience
Hi Kling 3,
you say you use 002r with the dua1 1.25 FW 800 ? I note from Digi compatibility info, that although this is a recommended machine, that a PCI firewire card should be used, which seems pretty strange. Quote:
I need to upgrade from my G4 450 machine, and there are some great offers going on the later G4 duals (I also have 002 ), so curious to hear if it all runs ok, or if your slight "delays" in responsiveness might be due to this firewire 800 stuff? Do you have any other odd things happening, eg delays in "save as" for example ? Thanks for any info.
www.kitestudio.co.uk Mac Pro Snow Leopard 003 & Midas Venice desk Mindprint DTC Soundelux U99 Drawmer M-Clock |
Kite,
I'm aware of the PCI card for firewire drives. However I'm using an internal IDE just as Digi recommends. So as far as I'm concerned, I shouldn't have any issues or prompts. I will play some more today and let you know if anything else strange happens. Launched PT this morning and everything was fine. I would like to know the proper startup sequence though. What gets turned on first, the 002r or the CPU? Or does it matter?
002r/MacPro 2.8/8-core/10.6.4/PTLE 8.0.4/two internal 500gig drives/8GB ram. |
Correct me if I'm wrong... but the motormix uses MIDI to recieve and send info right? And the 002 uses FW...
Got the idea?
Think Diferente! |
OK quik question . Why would any1 be looking for a 002 or sumthing similar when there is a 56 channel mixing board? Do you run LE on an SSL ? It seems silly to be judging the 002 and giving advice from the point of view which you stand in. I work at a larger professional studio and I dont thing they'll ever look at a 002 . Well my opinion is that the 002 is the best thing that happened in home studios. Full fader automation and control .only a simple firewire conection. I have it at home and love it. For a home setup it is great , but for a 56 channel mixing board studio ? why would you even look at it
Jacki-O, poe lil rich girl ALBUM OUT OCT.26 |
Yeah, 002 rocks.
I used the MotorMix for quite some time with the 001. my beef against it is that there are too many multi-function buttons on it, and no touch-sensitive faders. Favorite feature of the 002 is the FLIP switch of the faders!!!!
www.CaveCyberNation.com |
#16
Well, our 56 channel board is a mackie 32*8, and the 24 channel add on.. And we had 5 ADAT's.. This was all at the studio before I got there.. We desperately needed some sort of DAW, but we didn't have enough of a budget to go with a Mix system, or HD system, and still get everything we needed. (Computer, wiring, etc).. So, we decided to go with the 002R for right now, and then upgrade in a year or two.. I know, it's a round about way to go, but the owner and other engineer hadn't really used a DAW except for Magix Music and an old version of Cakewalk, so they weren't exactly convinced to spend $10,000 right away because they thought it all sounded mediocre at best, and thought that you just couldn't do much with it.. Add to that the fact that the other engineer is sort of afraid of computers due to ignorance, and it just becomes sort of a mess.. The 002R was basically my chance to prove that DAW's are very useful and can sound great as well..
So, now we've just bought 2 HD24's, which are supposed to have better converters (24 bit as well), and we're going to be upgrading A/D/A converters and WordClock.. We basically record to the HD24's, use our outboard gear for tube preamps, etc, then we go through a MOTU2408 to get it to the Mac, then use PT to do a good mix/editing/etc.. My job for coming to the studio was to bring us up-to-date on things.. Not that analog isn't good, but we really needed that jump into the current century.. However, as the new guy, I didn't have the oppurtunity of an unlimited budget.. Yada, yada.. So, hopefully you will see why we went with a 002R instead of a TDM system.. The money just isn't there right now, and won't be for a good while.. We're also redoing the interior of the studio, and expanding the control room.. Right now the CR is about 4' x 9'.. With 4 people it's VERY cramped, and isn't great for a listening room.. SO, we're taking baby steps to becoming a better studio.. Maybe not the most efficient way at becoming a "large" studio, but our rates aren't out of this world either.. We charge $40/hr - $50/hr, so we're not out to become rich, we just love to help bands make music, and not become this place that bands wish they could come, but couldn't afford it unless they sold their souls to a record label.. I'd love to work for a huge recording studio with a seemingly limitless budget, but I get free reign here.. I'm Chief Engineer, I'm getting a lot of experience that I couldn't get anywhere else, and I'm getting to see a lot of my ideas come into fruition.. Oh, and the money isn't too bad eric |
#17
The motor mix uses only 127 steps of resolution (midi) The 002 uses 1027 steps of resolution. I've heard that the HUI actually uses 1027 steps of resolution too, so it might be a better choice that the motor mix. I have the standard 002 and it works great for me.
#18
002 rocks!!!!!!!!
SG |
#19
Hi again Kling 3,
thanks for the info-thought that maybe you were not using a FWire drive ! So, answer to your question -according to Digi, and also my experience, boot up your Mac, and then switch on 002, plus any FWire drives (which you don't use !). Then fire -up Pro Tools. This order of start up is supposed to ensure a better communication with firewire ancillaries....that's the theory, and that's what seems to work just fine for me (I use Glyph Project X firewire drive, plus a Glyph scsi ultrawide, via Atto scsi pci card on my G4 AGP 450) all the best
#20
"ladewd & byteme, What about audioeric's earlier post - stating "(002) didn't lend itself to adding more faders easily." Have either of you encountered this problem? " I don't understand this. Why would you need to add more faders with just 32 tracks? 4 Pages is not much to skim through. I also hate the fact that the motor mix is motion sensitive and not touch sensitive. The surface feels cluttered to me, and it looks and feels very unprofessional. The 002 feels very close to the focusrite control surface. It's like a little nephew of it. It was built for pro-tools, so you don't have all of these extraneous (anonymous) buttons. Plus MIDI's accuracy doesn't compare to the 002's firewire. AJ |
Version 3.1.2 - could someone share the experience? | ALSTUDIOS | Artist Series | 12 | 03-09-2014 12:34 PM |
PT 11.0.1 with OS X 10.7.5 Please Share Your Experience | Numi | Pro Tools 11 | 0 | 07-15-2013 06:15 PM |
MBox2 and Cubase SX 3 .. please share your experience | Siddharth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-25-2007 04:30 AM |
MBox2 and Cubase SX 3 .. please share your experience | Siddharth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-25-2007 12:45 AM |
Share your A7V266-E and XP experience... | Recite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-26-2001 02:09 AM |
