Old 01-18-2006, 11:12 PM
jepmus jepmus is offline
Default MIDI Bank Select Entries Not Being Retained in PT7
Hi folks,
This midi related problem seems new to PT7 ... I am now using 7.1 cs3.
When entries are typed in the bank field in the patch select dialog, they are not retained. Dashes replace the data entered in the bank select fields. Program numbers, however, are kept. Can others replicate this behavior? If so, I hope the problem is fixed soon.
thanks,
jep
PT HDX - PT 23.9.0.155
Mac Studio M1 Ultra - 128gigs RAM - HD/IO with A/D Expansion -Sonnet Echo Express III TB3 upgrade - OS 13.4.1
Old 01-19-2006, 07:55 AM
Default Re: MIDI Bank Select Entries Not Being Retained in PT7
Digi, can you reproduce this behavior?
Old 01-19-2006, 09:44 AM
DigiTechSupt's Avatar
Yes, we are aware of this and have logged it to be fixed.
Avid Audio Tech Support
Support FAQ
Old 01-19-2006, 03:39 PM
thank you,
jep
Old 06-14-2006, 11:42 AM
Will this problem be fixed anytime soon, or is it no longer logged?
Thanks very much,
Old 08-27-2006, 06:13 AM
I just finished a job, and was able to upgrade to 7.2 yesterday ... It is hard to believe that this problem still exists. I started this thread in mid-January of '06
Please Digi, is this very basic midi function likely to be fixed in an early 7.2 cs update?
One of the primary reasons we use computers is the ability to recall data. It is difficult to understand why this problem has not been addressed ... and don't get me started about patch lists
thanks,
jep
Old 08-27-2006, 07:18 AM
hearttimes hearttimes is offline
how come you guys don't use cherrypicker? at least until they sort this out?
Old 08-29-2006, 06:29 AM
CherryPicker helps with converting patchlists; I don't believe it will correct ProTools' recent inability [as of PT7] to retain Midi Bank Select entries.
jep
Old 08-29-2006, 08:24 AM
when i use the pop up lists in pt 6.9 made with cherryp all works fine. banks are chosen correctly, etc. personally i would find entering the bank and patches manually in the event list a lot more of a hassle.
how come you guys don't like the pop-up lists?
are you saying that in 7 pop up lists do not work?
(strangely i recall this was once a problem in the late 4 or early 5 versions for a rev or two)
Old 08-31-2006, 06:07 AM
Try this Hearttimes,
In the edit window, selct program change view on a midi track.
Type bank select data in the corresponding fields.
Since Version 7, ProTools has become incapable of accepting/saving this data.
I am not talking about patch lists here; that's another matter
http://tinyurl.com/l43vg
thanks,
jep
MIDI Bank Select/Program Change octathorpe Pro Tools M-Powered (Mac) 0 10-13-2008 10:58 AM
Digi003/PT LE 7.3/WinXP/MIDI Bank changes not retained allegrarc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-16-2007 06:34 AM
Midi Bank select in 7.3 problem a100man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-10-2007 08:22 AM
Midi bank select & Program Change d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-01-2003 12:32 AM
PTLE 6.0.1 MIDI Bank Select? swheaton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-09-2003 01:22 PM
