Old 11-30-2004, 04:18 PM
pockets745 pockets745 is offline
Default Long, long Time loading PTLE on G4 DP 1.25!!
I've had this problem since I first installed PT on this at the time brand new G4 mirror door system. I have tried everything from repairing permissions to trashing prefs, turned off options, created new users. Nothing works. PLEASE tell me I don't have to completely re-install the OS, because that would require re-installing a ton of plug ins and authorizations.
any other suggestions?
Thanks
Jimmy
Old 11-30-2004, 04:24 PM
Default Re: Long, long Time loading PTLE on G4 DP 1.25!!
Try removing all 3rd party plug-ins.. and see if the problem persists.
I take it you've followed all the suggestions in the sticky troubleshooting thread at the top of this forum?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-30-2004, 04:57 PM
Yes, and i believe i tried removing the plugs, because that's where it seems to get tied up. But if that's what it is, I still don't know what the fix is. I've installed the plug in updates. I'll try to see if i can isolate it further. Thanks for your help!
Jimmy
Old 11-30-2004, 05:09 PM
Your first step is to locate exactly which plug-in it is.. once you've localized the issue.. take it from there.
Are you using the VST wrapper?
Rail
Platinum Samples
File name too long & Loading Plugins Preference not kept robertmonroe Windows 0 08-17-2011 01:02 PM
PT LE Long Loading Time jimst57 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-01-2007 12:58 PM
Long Pause while loading, searching for wave files bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-16-2004 09:00 AM
PT crash when loading too long audio file names? Helge Krabye Post - Surround - Video 3 06-04-2004 02:20 PM
Too long for comfort... problems with long session files Burton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-20-2001 06:51 AM
