Old 06-12-2019, 09:53 AM
lvly5t lvly5t is offline
Default Getting a status bar when moving clips left/right
Im getting a status bar/load bar/render bar/ every time I move a clip left/right
that says "class Tplaylistcommand" and i'm not sure what that is or what it is doing. It does interfere with my workflow for fast editing though. any help?
All system info is in my profile
Old 06-12-2019, 10:36 AM
Default Re: Getting a status bar when moving clips left/right
So upon messing with it further it appears that only when I edit a clip in the playlist drop down section does it cause this status bar thing to happen.
when I move a clip in the main track playlist it does not happen.
I am uploading a picture to give a visual
when I move the purple clip (circled in green) on the main track (also circled in green) every thing is normal
when I move the red clip (circled in red) on the playlist track (also circled in red) it does cause the load/render window
Old 06-13-2019, 10:01 PM
Paul Cardon Paul Cardon is offline
Same issue here! Are you on 2019.5?
20 tracks, about 40 playlists, getting that "class Tplaylistcommand" with certain types of simple edits, normally when I pick up and move a single clip or fade. Can keep Pro Tools frozen for up to 60 seconds sometimes.
Intel i9 9900k, 32GB of high speed RAM, project and OS are on separate SSDs.
Wanna guess it's a 2019.5 issue as I've never ran into this before now.
Old 06-19-2019, 07:10 AM
Oli_W Oli_W is offline
Same issue here - on 2019.5 (was the same on previous version too)
Really annoying for Classical Edits.
i7 3770k
Asus P8P67
16Gb Ram
Samsung SSD
GT 1030 GPU
Moving clips vertically paldry Pro Tools 12 6 08-14-2018 08:20 AM
Beat Detective Moving Clips 3peacestudios Pro Tools 12 0 12-07-2017 07:50 AM
moving clips fmilian Pro Tools 11 6 05-08-2015 05:11 AM
moving all the clips! TakenGrace Pro Tools 11 6 06-21-2014 01:07 PM
Moving MIDI clips causes them to consolidate abt Pro Tools 11 9 04-07-2014 09:07 PM
