Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
  #21
Old 11-30-2020, 08:24 AM
Chris August Chris August is offline
Default Re: Pro Tools Carbon Laptop Fan Noise
Hey Mark! Yes, my support code is 04065976.
Thanks!
Chris
  #22
Old 11-30-2020, 09:15 AM
MCorbin's Avatar
MCorbin MCorbin is offline
Default Re: PT Ultimate I/O Problem
Hey Chris
If you have not already created a case, could you please do so and let me know the Case number so we can work on a solution for you?
Thanks!
Mark
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
  #23
Old 11-30-2020, 12:03 PM
MCorbin's Avatar
Thanks Chris, I'll make sure it gets picked up asap.
Mark Corbin
  #24
Old 12-18-2020, 02:45 AM
nstu nstu is offline
I have the same problem with my Mac Pro 6.1.
The fan get to the max when Carbon is active.
I also opened a support ticket. Hope they get a quick fix. I really really like carbon. Was a good decision to make the change from may Apollo silver
Gesendet von iPhone mit Tapatalk
  #25
Old 01-21-2021, 08:28 AM
Technog0d Technog0d is offline
I am also having a problem with the fan noise and high CPU. I noticed that the AvidAppManHelper is eating up a lot of CPU and mem too.
  #26
Old 02-24-2021, 08:56 AM
thealtsax thealtsax is offline
Hi, I've the same problem here on my Macbook Pro 15-inch, 2019, 2,3 GHz Intel Core i9 8 core.
In my case, the cpu work remain low.
I've just opened a case at Avid support.
Regards
  #27
Old 08-10-2021, 06:06 AM
U.KUSTIK U.KUSTIK is offline
Hi, thought I‘d give AVIDs hardware a shot, as it is best implemented into ProTools. I bought a Carbon end of June and can‘t get it to work flawlessly since. The fans instantly go up when I plug it into my MacBook Pro, 15“, late 2019, 8-core i9, 32 GB RAM, Catalina. The kernel_task „explodes“ and coreadio seems to crash a lot. So basically I have a a brilliant result of engineering in my studio, that I can‘t use for professional purposes.
I need it up and working till next week as I‘ll be out recording for the European Parlament (cultural department) and can‘t risk a system-fail.
This problem is known since end of last year. So there for sure is a fix already baked right?
Kind regards form Vienna Austria, Ulrich
  #28
Old 08-10-2021, 08:30 AM
JFreak's Avatar
JFreak JFreak is online now
Originally Posted by Chris August View Post
Not Responding
When a process says this on Activity Monitor it means there is incompatibility or a bug. Unfortunate for you, but let's assume it is not a bug because there are many happy campers so please double check your OS and PT versions. After that also double check whatever plugins you are using, because even single bad plugin may cause that. Easiest check for plugins is to throw everything to unused folder as PT will copy core plugins back and you will instantly know if it is some third party plugin that caused your trouble.
Janne
  #29
Old 08-10-2021, 09:10 AM
dominicperry dominicperry is online now
Sadly not true here. The CoreAudioD process goes nuts as soon as an AVB device is connected. It happens in Catalina (10.15.7) and Big Sur (I've tried 11.2, 11.3 & 11.5 & 11.5.1).
I don't have any other AVB devices to try ('cos it's a nuts way of attaching an studio project audio interface), but I suspect the problem is Apple's, not Avid's.
The only reason I think I can use the Carbon with immunity from drop-outs and laptop-fan noise, is because I'm using a Mac Pro, not a laptop.
If the Carbon fan is ramping up, then you have a different problem - either you're not using the updated firmware that came with PT 2021.6 or it's hot where you are, or the Carbon doesn't have enough ventilation. I guess there could also be a hardware problem.
  #30
Old 08-11-2021, 03:29 AM
Hi dominicperry, thanks for the quick response! I've checked if it's a plugin issue, but they seem to integrate flawlessly without using up the CPU. Unfortunately I can't put a MacPro in our budget right now. This would solve my issues I guess. Still my Laptop is in the computability-chart of AVID and my thought was to buy a system that distresses the CPU of my MacBook, not the other way round.
The Carbon itself shows no real fannoise. The thing itself is just a brilliant piece for producers like me. In case it finally will work as planned ^^
I opened a case at AVID-Support and hope they have a quick fix ready. Need it up and running by next week ><
Pro Tools | Carbon Avid Technical Alerts 0 11-12-2020 03:14 PM
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? PeterGreen Pro Tools 10 24 01-23-2013 06:38 AM
Static Noise with Pro Tools LE and laptop jallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-17-2007 10:43 PM
