Old 09-20-2018, 06:21 PM
leggylangdon leggylangdon is offline
Default Selecting track on S3 scrolls to view in Edit/Mix Window
Does anyone know if this is possible? Or if it should be happening and there is a bug?
Essentially the opposite workflow from selecting a track with mouse in Pro Tools and the S3 then scrolls to that track (which is happening fine)
I have 'Select by Touch' in Econ Prefs selected. So then if I touch a fader on S3 the track is selected on the S3 and its also selected in Pro Tools, but the Edit/Mix window doesn't update and scroll to that track. Is that normal? If so, I think that should be changed. If I select a track on my S3 id love Pro Tools to show me the track as well.
Any thoughts, or ideas would be greatly appreciated
Cheers
Leggy :)
Old 09-21-2018, 09:49 AM
EddieJones's Avatar
Default Re: Selecting track on S3 scrolls to view in Edit/Mix Window
There's only the Edit and Mix window Scrolls when banking at the moment..its on the list to do....
Old 09-24-2018, 12:34 PM
JR Fountain JR Fountain is offline
Unless I'm missing what you are after, just hit ctrl+track sel and that'll do it.
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 10-28-2018, 10:58 AM
Eddie - Thats great to hear!
JR Fountain - Yes! That works for now and is a greta work around! I think the more streamlined version of this would be to have a pref setting of 'Select fader by touch banks Edit/Mix Window'
Thanks for your replies! :)
Old 01-26-2021, 08:59 AM
ViciousLullabyz ViciousLullabyz is offline
Hi Eddie
Has this ever made it into a release yet?
If not, is there any other way to do the following:
Having closed folders and master vca visible only in PT. spilling master vcas and then tracks from the sub vcas. is there any way to then have them scrolled into view/opening the respective folders in PT?
Old 01-26-2021, 10:51 AM
EddieJones's Avatar
This works for me if I have autobank to selected track and App banks DAW on in the Control App.
Old 01-27-2021, 08:15 AM
Personally I wish that one could do this with a modifier key: select a track on the surface and edit window scrolls to it (IOW exactly what shift-ctl-click does on the edit window only selecting with the surface). I usually don't want attentioned tracks on the surface to scroll the edit window, but want to occasionally - would be great to be able to do it from the surface without changing prefs. Or perhaps I'm missing something?
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Edit window moves on selecting clip tooold Pro Tools 11 3 12-02-2014 12:13 PM
Is there a way to automatically bring a track you select into view in the edit window Focuret Artist Series 4 01-05-2013 01:48 PM
View-Other displays-track list and regions list, only from edit window? crizdee Pro Tools TDM Systems (Mac) 0 02-27-2009 10:46 AM
Problem selecting region in edit view, PTLE6.4, Digi 001 rusmooth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-14-2008 07:34 PM
Quick key for changing edit view to volume view in track? postman56 Pro Tools TDM Systems (Mac) 4 11-30-2007 10:56 AM
