Old 06-24-2012, 10:22 PM
birdfluvirus birdfluvirus is offline
Default Latency issues (pro tools and control panel show different values...)
Mbox 3 pro
Win 7 64bit
Intel cpu with Nvidia motherboard (yes I know this is bad, but it has worked before without issue.)
1. Open new session, add tracks, record, add plug-ins. No Problem.
close session for the day. Come back next day and I hear a major delay when recording. No preferences or anything were changed. Just shutting down computer and starting the next day.
2. My Mbox control panel in general setup shows my Buffer size (latency) as 128 but in my playback engine in pro tools it shows 256. I can not make them the same. If I change my buffer size in pro tools the control panel changes to the option just under the pro tools buffer size. Ex. 512 in PT and 256 in control panel. I can make the PT 64 and the control panel 64 but I get audio artifacts and I still get noticeable latency from my input device.
3. My playback often stops working and if i check the minimize additional I/O latency box i get sound again. Then it will cut out after I am editing or mixing and then I check the box again and the sound comes back. So wierd.
I have also done a lot of research and made my rig very PT friendly. At least as much as possible without getting a new computer.
Here is my sandra report. Please help!!!
***** Start of Report *****
<<< Computer Overview >>>
< Computer >
Model: EVGA 132-CK-NF79
Serial Number: 1
Chassis: EVGA Desktop
Mainboard: EVGA 132-CK-NF79
Serial Number: 1
BIOS: Phoenix Technologies, LTD 6.00 PG 03/15/2008
Total Memory: 6GB DIMM SDRAM
< Processors >
Processor: Intel(R) Core(TM)2 Duo CPU E8400 @
3.00GHz (2C 3GHz, 6MB L2)
< Chipset >
Memory Controller: nVidia nForce 790i Host Bridge 4x 333MHz
(1.33GHz) FSB
Memory Controller: nVidia MCP55 Memory Controller 2x 1.67GHz
(3.33GHz) FSB, 6GB DIMM SDRAM 1GHz
< Memory Module(s) >
Memory Module: OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U
DDR3-1066 (7-7-7-16 4-26-8-4)
< Video System >
Video Adapter: NVIDIA GeForce GTX 470 (448 SM5.0 1.22GHz,
1.3GB 3.35GHz 320-bit, PCIe 2.00 x16)
< Graphics Processor >
OpenCL GP Processor: NVIDIA GeForce GTX 470 (448SP 14C 1.22GHz/
1.22GHz, 1.3GB 3.35GHz 320-bit)
Compute Shader Processor: NVIDIA GeForce GTX 470 (448SP 1.22GHz/1.22GHz,
CUDA GP Processor: NVIDIA GeForce GTX 470 (448SP 14C 1.22GHz/
< Storage Devices >
Seagate ST3200822A (200GB, ATA:186GB (G:) (H:)
WDC WD2500AAJS-00B4A0 (250GB, :233GB (C:) (E:)
WDC WD1500AHFD-00RAR1 (150GB, :140GB (D:)
WDC WD15EADS-00P8B0 (1.5TB, SA:1TB (Z:)
PIONEER DVD-RW DVR-112D (622.:594MB (I:)
< Logical Storage Devices >
Downloads (G:): 146GB (NTFS) @ Seagate ST3200822A (200GB,
ATA100, 3.5", 8MB Cache)
Reserved (E:): 100MB (NTFS) @ WDC WD2500AAJS-00B4A0 (250GB,
SATA300, 3.5", 7200rpm, 8MB Cache)
Downstack (D:): 140GB (NTFS) @ WDC WD1500AHFD-00RAR1 (150GB,
SATA150, 3.5", 10000rpm, 16MB Cache)
Archives (Z:): 1TB (NTFS) @ WDC WD15EADS-00P8B0 (1.5TB,
SATA300, 3.5", 32MB Cache)
Files (H:): 40GB (NTFS) @ Seagate ST3200822A (200GB,
Boot (C:): 233GB (NTFS) @ WDC WD2500AAJS-00B4A0 (250GB,
Audio CD (I:): 0bytes (CDFS) @ PIONEER DVD-RW DVR-112D
(622.7MB, ATA66, DVD+-RW, CD-RW, 64kB Cache)
< Peripherals >
LPC Hub Controller 1: nVidia MCP55 LPC Bridge
LPC Legacy Controller 1: Winbond W83627DHG
Audio Device: nVidia MCP55 High Definition Audio
Audio Codec: Realtek Semi 888 High Definition Audio
Audio Device: EVGA GF100 High Definition Audio Controller
Audio Codec: nVidia Mutara V08 [NV2]
Serial Port(s): 1
Disk Controller: nVidia nForce 790i Memory Controller
Disk Controller: nVidia MCP55 Memory Controller
USB Controller 1: nVidia MCP55 USB Controller
USB Controller 2: nVidia MCP55 USB Controller
FireWire/1394 Controller 1: nVidia TSB43AB22 1394a-2000 OHCI PHY/Link-
Layer Controller
SMBus/i2c Controller 1: nVidia MCP5 SMBus 1
SMBus/i2c Controller 2: nVidia MCP5 SMBus 2
< Printers and Faxes >
Printer: Microsoft XPS Document Writer (600x600,
Colour)
Printer: HP Deskjet 3050A J611 series (600x300,
Colour)
Colour)
Fax: Microsoft Shared Fax Driver (200x200)
< Scanners and Cameras >
Scanner: Hewlett-Packard HP Deskjet 3050A J611 series
(NET) (Scanner, USB)
< Network Services >
Network Adapter: NVIDIA nForce 10/100/1000 Mbps Ethernet
(Ethernet, 100Mbps)
Network Adapter: NVIDIA nForce Networking Controller #2
(Ethernet)
< Operating System >
Windows System: Microsoft Windows 7 Home 6.01.7601 (Service
Pack 1)
Platform Compliance: x64
< Windows Experience Index >
Current System: 5.9
<<< Processor Arithmetic >>>
< Benchmark Results >
Aggregate Native Performance: 25.44GOPS
Dhrystone Native ALU: 31.54GIPS
Whetstone Native SSE3: 20.52GFLOPS
Results Interpretation: Higher Scores mean Better Performance.
Decimal Numeral System (base 1:1GOPS = 1000MOPS, 1MOPS = 1000kOPS, 1kOPS =
1000OPS, etc.
< Performance per Thread >
Aggregate Native Performance: 12.72GOPS
Dhrystone Native ALU: 15.77GIPS
Whetstone Native SSE3: 10.26GFLOPS
Number of Threads: 2
1000OPS, etc.
< Performance vs. Power >
Processor(s) Power: 52.940W
Aggregate Native Performance: 480.49MOPS/W
Dhrystone Native ALU: 595.71MIPS/W
Whetstone Native SSE3: 387.55MFLOPS/W
< Performance vs. Speed >
Aggregate Native Performance: 8.48MOPS/MHz
Dhrystone Native ALU: 10.51MIPS/MHz
Whetstone Native SSE3: 6.84MFLOPS/MHz
Current Processor(s): 6.6
< Benchmark Status >
Result ID: Intel(R) Core(TM)2 Duo CPU E8400 @
Computer: EVGA 132-CK-NF79
SMP (Multi-Processor) Enabled: Yes
NUMA Support: No
Processor Affinity: C0T0 C1T0
System Timer: 2.93MHz
Number of Runs: 64000 / 640
< Processor >
Model: Intel(R) Core(TM)2 Duo CPU E8400 @
3.00GHz
Speed: 3GHz (100%)
Minimum/Maximum/Turbo Speed: 2GHz - 3GHz
Peak Processing Performance (P:24GFLOPS
Adjusted Peak Performance (APP:7.2WG
Cores per Processor: 2 Unit(s)
Threads per Core: 1 Unit(s)
Type: Dual-Core
L1D (1st Level) Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64
byte line size
L2 (2nd Level) Cache: 6MB, ECC, Synchronous, ATC, 24-way, 64 byte
line size, 2 threads sharing
< Features >
SSE - Streaming SIMD Extension:Yes
SSE2 - Streaming SIMD Extensio:Yes
SSE3 - Streaming SIMD Extensio:Yes
SSSE3 - Supplemental SSE3: Yes
SSE4.1 - Streaming SIMD Extens:Yes
< Performance Enhancing Tips >
Tip 223: CPU speed, under load, lower than rated
speed. Check power management settings.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Multi-Core Efficiency >>>
Inter-Core Bandwidth: 3.13GB/s
Binary Numeral System (base 2):1GB(/s) = 1024MB(/s), 1MB(/s) = 1024kB(/s),
1kB(/s) = 1024 bytes(/s), etc.
Inter-Core Latency: 39.0ns
Results Interpretation: Lower Scores mean Better Performance.
Decimal Numeral System (base 1:1s = 1000ms, 1ms = 1000µs, 1µs = 1000ns, etc.
Inter-Core Bandwidth: 1.57GB/s
Inter-Core Bandwidth: 60.60MB/s/W
Inter-Core Latency: 7.37ns/W
< Capacity vs. Power >
Total Cache Size: 117.26kB/W
Inter-Core Bandwidth: 1.07MB/s/MHz
Inter-Core Latency: 0.13ns/MHz
< Detailed Results >
Processor Affinity: CPU0-CPU1
1x 64bytes Blocks Bandwidth: 519MB/s
4x 64bytes Blocks Bandwidth: 649MB/s
4x 256bytes Blocks Bandwidth: 1.86GB/s
4x 1kB Blocks Bandwidth: 3.71GB/s
4x 4kB Blocks Bandwidth: 5GB/s
16x 4kB Blocks Bandwidth: 9.1GB/s
4x 64kB Blocks Bandwidth: 13.08GB/s
16x 64kB Blocks Bandwidth: 13GB/s
4x 1MB Blocks Bandwidth: 13GB/s
8x 1MB Blocks Bandwidth: 1.85GB/s
16x 1MB Blocks Bandwidth: 1.47GB/s
8x 4MB Blocks Bandwidth: 1.5GB/s
Buffering Used: No
SMC (Multi-Core) Enabled: Yes
Page Size: 4kB
< Processor >
3.00GHz
Speed: 3GHz (100%)
Type: Dual-Core
byte line size
Warning 5010: Cannot use Large Memory Pages due to lack of
privileges.
tip.
<<< Media (Audio/Video) Transcode >>>
<< HD TV (H.264 1280x720/30p @ 4Mbps; AAC 2x 16-bit @ 192kbps) >>
<< Hardware Accelerated >>
Error (346): Transcoding failed. Use software transcoding
or check transcoders installed.
<< Software >>
<< Full HD TV (H.264 1920x1080/30p @ 8Mbps; AAC 2x 16-bit @ 256kbps) >>
<< Software >>
<< HD Streaming (H.264 1280x720/30p @ 2Mbps; AAC 2x 16-bit @ 128kbps) >>
<< Software >>
<< SD TV (H.264 720x480/30p @ 3Mbps; AAC 2x 16-bit @ 128kbps) >>
<< Software >>
<< Embedded (H.264 480x320/30p @ 1.5Mbps; AAC 2x 16-bit @ 128kbps) >>
<< Software >>
<< Phone/Player (H.264 320x240/15p @ 500kbps; AAC 2x 16-bit @ 96kbps) >>
<< Software >>
***** End of Report *****
Pro Tools 9 and Mbox control Panel Beourg Pro Tools 9 2 12-04-2012 11:01 PM
Control Panel Issues... List them here. Loudnoize Ent. Pro Tools M-Powered (Mac) 1 06-24-2012 10:24 PM
Control Panel and Pro Tools show different buffer size (latency). birdfluvirus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-10-2012 09:11 PM
Digi001 doesn't show up in XP Sound Control Panel MaizeBass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-06-2002 07:07 PM
001 inputs don't show up in sound control panel jghere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-02-2001 09:28 AM
