Re: Will there be a new version of Pro Tools in 2018?
10.14.2 just out
Thanks.
Sorry if this is in the incorrect thread but i did not want to create a new one.
Its just a heads up on a 20 percent discount (today only) on Pro Tools plans/software upgrade. From KMR. Choose store delivery option for digital download. use code <XMASDEAL7> https://mailchi.mp/kmraudio/12-exclu...-for-christmas Please move/remove Jeffro if it goes against any protocol. |
#16
#17
Are you saying that 10.13.3 is 5 years old ??
Just so you know many people are using the newer OS and Mojave works kinda great as we gave one of our trashcans a go so why not just make a backup and try Mojave on a new ssd drive? Works well here and for most people here on the forumz
#18
Why don't you start your own new thread, clearly listing your systems specs and all the standard and other troubleshooting you have done, and confirm you system is fully optimized (check *every* last optimization thing is done, no matter how inconvenient at least until you have a more stable system). Starting your own thread for serious issues is really what is expected here, you are not going to get the same help by dropping occasional posts onto other threads, unless they are directly related to the issue. If this is killing you what has Avid support said? Do you have a case # (for Avid folks here). What exact errors do you get and when did this start happening? (what exactly changed). What sample rate and IO buffer size are you using with what interface? What driver version? What make/model disk drives and where are the audio files? Standard troubleshooting things you especially should have already tried are moving all .aaxplugin files out of the plugin folder (you've made points in other post about not using plugins in sessions, but the more important test is to get all third party plugins out of Pro Tools). trashing prefs, testing with new empty sessions, testing with Built-In output as the playback engine, creating a new admin account and repeating the testing from there. Trashing prefs as you try those different things. Make sure ignore errors is not checked, disk cache is enabled (set to a size not "normal") and dynamic plugin processing is turned off (not likely an issue in your case from what you've described elsewhere but jet get it off). Especially if your OS has been upgraded in-situ and nothing else is helping then bite the bullet and do a full clean macOS install onto a spare drive or partition and only install Pro Tools and ILM and test using Built-In Output. If that has problems then especially let us know here, Avid should be all over that.... That ultimate reinstall test should take an hour or two elapsed time so not the end of the world. |
#19
This depends on how long you lapse for. I have lapsed for so long now that I have saved more than what it would cost to get current. Still nothing to entice me to get current.....so still saving $$$
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
#20
Have you tried turning off hyperthreading?
10.13.6 with 2018.7 ... best version ever!? Holy Sssh | Mattian | Pro Tools 2018 | 95 | 10-14-2021 10:09 AM |
Is Pro Tools 2018 EVER going to be supported on a current Version of High Sierra? | off the wall | macOS | 10 | 01-05-2019 04:53 PM |
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations | matthewmkb | macOS | 0 | 06-27-2018 06:33 AM |
Permission Denied (13) on Launch -Pro Tools 12, Version 2018.1 | Randroo | Pro Tools 2018 | 7 | 05-07-2018 08:11 AM |
Does the 2018 boxed version come with iLok 2 or 3 and ... | rique000 | Pro Tools 2018 | 3 | 02-23-2018 06:11 PM |
