Old 08-08-2002, 10:51 AM
Stu Barbour Stu Barbour is offline
Default Dodgy Mac Date and Time
I have just changed over to Mac from PC and all is going well with pro tools, the only problem is every time I switch on my mac, the date and time have changed to anything from 1900's to 2040 ! It is getting really irritating. I changed the battery and als "zapped the p ram" but it still does it. Any ideas ?
Old 08-08-2002, 11:27 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Dodgy Mac Date and Time
Are you setting the Date & Time Control Panel to the current time and also selecting a Time Zone? (whenever you zap the PRAM it defaults to no time zone and needs to be reset)
Administrator
Old 08-08-2002, 04:21 PM
dmcgilli dmcgilli is offline
Depending on the age of your computer, the watch battery that keeps the PRAM data alive when you turn off your mac may be dead. It looks like a watch battery on your motherboard.
if the pref. thing doesnt work, that may be why.
Daniel
Old 08-09-2002, 12:20 AM
Nine Spine Nine Spine is offline
I had this same problem on my ibook for a while, but I trashed the Date and Time Preferences and then made sure my clock was not set to get it's time and date from a network, and it has worked fine ever since. Maybe this will help.
I.B.S. Studios
Old 08-09-2002, 01:12 AM
thermoboy thermoboy is offline
There is a known bug with dates and time when you often switch between Mac OS 9.x and a certain version of OSX (10.1.3 or lower I think). The 2 clocks seem always out of sync, and fixing one in OSX makes the one in OS9 go mad and vice versa. I've had this problem for a long time, until I upgraded to the latest version of OSX.
Hope this helps
Aloha
Thermoboy (from Reunion Island)
http://www.thermoboy.com
Thermostudio powered by :
G4 DP 2x500 Mhz / Digi 001
[working on 1st self-prod. LP]
Old 08-12-2002, 04:55 AM
Thanks, I'll have another go at it.
Time and Date not right Music 101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-22-2010 11:28 PM
G5 date and time issue spidey01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-19-2009 09:30 AM
Date Modified -- any way to get time information? c-post Pro Tools TDM Systems (Mac) 1 01-06-2007 09:17 PM
Dodgy Time Estimates Dan Pinder Aspera DigiDelivery 1 03-27-2006 04:15 PM
Date&Time keeps going to 1969 in 10.2.4. ? beatboy Pro Tools TDM Systems (Mac) 7 03-29-2003 07:56 PM
