Hi all,
I'm getting a notification of Pro Tools not able to perform delay compensation on three tracks. ![]()
The culprit is Newfanlged Audio Elevate, which is the last thing on the Router. If I disable this, I have no delay compensation warnings. I suspect this isn't an issue since I'm not ever coming back into Pro Tools or routing to anything in the mix once it hits the router aux. So, two questions: 1. Is this hurting anything, and if so what can I do about it? 2. If it is not hurting anything, can I somehow how flag them to remove the delay comp warning? I want that indicator to only show red if there is a real problem, and if I introduce a problem I currently won't notice since the indicator is always red. thanks to any who can help! :) James |
Newfanlged Audio Elevate by itself isn't the culprit it just adds too much latency to all the plugins you already have in your Router before or in another plugin chain in your session. It would be the same with Isotope Ozone f.ex.
If it's the very last plugin in your session it's not really causing issues. But your printed master-track will be delayed in relation to the session and of course the monitoring you are listening to.
Mac Pro 12 core 3.46Ghz - 64 Gb ram - SSD 500 Gb - HD1 2T - HD2 2T - OS 13. - Mac Book Pro retina- OS 13. - SSL Alphalink convertor - Pro Tools 12 native - SSL Matrix console - Logic Pro X |
Same happens with me with same plug in, though as mentioned if it’s last in your chain it doesn’t really matter with the exception that if you are mixing out files to send to someone to add instrumentation to it will be out of time when you import back into your session.
Sent from my iPhone using Tapatalk |
Thanks dannyg - that's what was I was thinking. It's annoying to see the red on the transport bar, but I can deal with it. :)
![]() Quote:
Aux Routing Weirdness / Ping-pong Delay Messes Up Delay Compensation | MKZ | Pro Tools 2018 | 2 | 11-22-2019 04:08 AM |
help fixing plugin delay and delay compensation disaster | prestonhavill | macOS | 14 | 12-24-2014 03:35 PM |
Delay compensation with backline delay | chuck goodwin | VENUE Live Sound Systems | 3 | 08-09-2013 07:54 AM |
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing | CNSound | macOS | 1 | 01-27-2012 11:10 AM |
Delay compensation- choice of 'Medium delay'? | dtmprod | Pro Tools TDM Systems (Mac) | 2 | 05-05-2010 11:00 PM |
