Hello!
So I have everything setup with my new KRKs, balanced cables going into my Focusrite 24, and using PT 9.0.5.[bleep] The issue I have now is when I try to play sessions I had from before, which were set to 48/24, I get a lot of distortion. My first thought was that the sample rates weren't the same, but the focusrite is set to 48khz. [bleep] It works fine with newer files at 96khz. I have my settings at: 3cpu (of 4), 65%, and 1024/512 samples. Rest is default.[bleep] I have tried with HD external on USB and focusrite on FW, [bleep]as well as firewire HD (FW800) from mac then next in chain is the Focusrite (FW400).[bleep] I have a MPB 15in, external G-DRIVE 2TB.[bleep] I updated the mixcontrol to 2.4, and downloaded the RTAS for the focusrite.[bleep] What can be causing this?[bleep] On top of that, I try to press play in PT at times and the play and stop buttons flash then nothing happens. Some have said its the samples (512/1024 etc) and ive tried changing to no avail.[bleep] Any help would be appreciated :) Thanks! |
Bump
Have you deleted your prefs and databases, I had a horrible problem with static until I did that once.
Do you have Setup > Playback Engine > Ignore Errors during Playback/Record > Minimize Additonal I/O Latency, selected? If so, deselect; Minimize Additonal I/O Latency. (this seems to be a bug in 9.0.5)
Pro Tools 12, Studio One V3.x iMac 27" 5k i7 4Ghz, 32GB RAM 1TB Flash (OS X 10.10.x) OWC Thunderbay Mini (4TB SSD) Interface: Antelope Audio Zen-Studio Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 Macbook Pro 8GB RAM, 512GB SSD Audio(mobile rig) |
Thanks! i will try that out. Hopefully it works. If not, hopefully someone else may know why.
The unchecking of 'minimize additional i/o latency' seems to have fixed both issues!
Thank you!! |
Glad to hear the distortion issue is resolved, you may still run into a problem with the play button, changing the h/w buffer to anything other than what it's currently set to, seems to temporarily re-enable it. DTS has said (in another thread) that it's an issue they are working to resolve.
Distortion between Focusrite MixControl and PT9 | pearldrum944 | Third Party Interfaces | 11 | 03-05-2014 01:57 PM |
cant get any distortion to sound good | alaskan eel | Eleven Rack | 18 | 09-04-2013 09:05 PM |
need to restart PT due to sound distortion | Martin Eriksson | Windows | 14 | 02-17-2013 02:26 PM |
Sound Distortion on Mbox2 | hipster0202 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-13-2006 02:51 AM |
Distortion when using 001 for sound manager | bal209 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-04-2001 09:56 PM |
