Old 10-19-2010, 11:00 AM
audioluche audioluche is offline
Default OT: OSX Loosing Date and time settings
Yesterday and today, when i booted my system, i've got an error message telling me that my date and time were wrong (it was set to 1969).
I am wondering what can the the cause of this?
Is it a battery on the G5 motherboard? Is it software only?
Do i have to worry?
Anyone have a clue?
system info: G5 dual 2.5 10.4.9, PT 7.4
Thanks!
Luc
Old 10-19-2010, 11:07 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: OT: OSX Loosing Date and time settings
Originally Posted by audioluche View Post
Do i have to worry?
Anyone have a clue?
Thanks!
Luc
Yes its the battery! if i remember the G5 is a small round battery about 1 inch long, it should be obvious if you pop the side down and peep in.
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-19-2010, 11:08 AM
Sean Russell Sean Russell is offline
Try OWC Macsales.com
... but does it help the chorus?
Old 10-19-2010, 11:12 AM
Chris
Thanks Chris, i will take a look at this.
Thanks Sean for the link!
Cheers,
Luc
Old 10-19-2010, 11:14 AM
Sean Halley Sean Halley is offline
That's the main reason why you shouldn't have your CPU on a power source that gets switched off when the rest of your gear does - it should only be running the battery when the wall power is cut off. That's usually what causes a motherboard battery to die prematurely, although with an eight-year-old CPU, it was bound to happen eventually.
Unplug your iloks until you know the date is correct!!
S..
"it's not about making the changes, it's about playing ideas in time"
Scofield...
Old 10-19-2010, 11:29 AM
studiojimi's Avatar
studiojimi studiojimi is offline
pull the batter out and take it to radio shack they usually have them
little yellow and purple ones usually
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 10-19-2010, 11:37 AM
S..
Really, this could hurt my iloks? Thanks for the advice!
Yeah, it's an old CPU but like a wise man said, i'm holding fast!!!
Cant wait to change it for a Mac Pro, will do it as soon as some new TDM cards will get launched. Well, i hope so
Luc
Old 10-19-2010, 11:38 AM
Thanks Studiojimi!
I will check that.
Old 10-19-2010, 11:42 AM
@ndy's Avatar
@ndy @ndy is offline
Buy it online. Radio Shack will charge you 800% for it in the store. They used to best place to get batteries. Not anymore. I only go there for the "I need it now" batteries. Don't even get me started on how they sell soldering irons with tips that are replaceable, but they don't sell the replacement tips. This is their own rebranded product by the way!
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
Time and Date not right Music 101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-22-2010 11:28 PM
G5 date and time issue spidey01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-19-2009 09:30 AM
UK date settings sheldon013 Aspera DigiDelivery 0 05-02-2007 05:31 AM
Date&Time keeps going to 1969 in 10.2.4. ? beatboy Pro Tools TDM Systems (Mac) 7 03-29-2003 07:56 PM
Dodgy Mac Date and Time Stu Barbour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-12-2002 04:55 AM
