Old 08-23-2010, 10:30 AM
darentsmith darentsmith is offline
Default Help Please - Waveform/Audio gone!
Hello all,
So weird thing just happened. Editing audio and get to a region that has no waveform. They were there before when I recorded the instrument (tbone), but now they're gone. I'm about 2/3 into the session and poof, a bunch of audio just isn't there anymore. The regions are sitting there in place, but no waveform, and no audio. Up to that point it was fine.
Any suggestions? Anyone run into this?
Thanks.
Daren
Old 08-23-2010, 11:23 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Help Please - Waveform/Audio gone!
Did u start or @ some point maybe import from a different drive?.. If the audio was there u could re-calculate but it sounds like a drive is offline...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-23-2010, 11:43 AM
formfunction formfunction is offline
Originally Posted by darentsmith View Post
Hello all,
As KeyBeetz said.. with disk allocation issues. did you get a pop up window when you opened the session saying that audio was missing? When you say "before" do you mean another day, or while that session has been open?
Losing audio is common when you don't have a handle on where your files are, disk allocation, and move your sessions around a bit, usually when copying in Finder, or dragging. Good Luck.. ff
Old 08-23-2010, 03:10 PM
Last I checked there was audio there, which was when it was recorded last thursday. Not sure what happened between now and then. As far as disk allocation, I checked that and all the audio has been saved to the same drive, so if the drive was offline I would know it.
Not sure guys. Weird. Thanks for the replies though.
Old 08-23-2010, 03:14 PM
Is the audio in the folder? Have you tried relinking? Importing? Going back to a saved version? What version of PT?
Old 08-23-2010, 03:32 PM
LanceK LanceK is offline
You can tell the regions to show the full path which will tell you if it's on another drive or not.
Old 08-23-2010, 06:03 PM
Ian Bodzasi Ian Bodzasi is offline
A couple of us have been having the same thing in 8.0.4...I'm about to downgrade to 8.0.3
http://duc.digidesign.com/showthread.php?t=277213
www.bodzasi.com
Old 08-23-2010, 08:09 PM
See this thread: http://duc.digidesign.com/showthread.php?t=264755
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Waveform doesn't match audio! Crackerpants 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-29-2013 03:08 PM
Audio but no Waveform innermusic Pro Tools 10 1 03-31-2012 10:46 AM
Can see waveform but can't hear audio missmbc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-17-2011 08:18 AM
Need PT8 to Quantize audio waveform? Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-27-2009 12:59 PM
audio waveform and mixer zzangsoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-02-2001 06:50 AM
