Old 06-20-2004, 01:45 AM
hanz marathon hanz marathon is offline
Default Midi Export bug in OSX
Hi Digi,
exporting midi under 6.4 OSX creates a file that has no extension to (.mid). Workaround is to put this in manually, but would be
much nicer just to have the '.mid'.
If you try to import these midifiles (without workaround) ProTools don't want to import them.....
www.marathon-music.com
Old 06-21-2004, 01:06 PM
DigiTechSupt's Avatar
Default Re: Midi Export bug in OSX
Exporting MIDI files does not append the .mid extension if Mac/PC compatibility is not checked when creating the original session.
There are two ways you can workaround this:
1. When you are trying to import the midi file into a session you can select Show: MIDI and change this to Show: All Documents in the import Midi dialog and then you can choose your Midi file and import it.
2. When you are exporting the Midi file you can type the name and add the .mid extension and save it. This will allow Pro Tools to see the file and import it.
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Old 06-21-2004, 05:05 PM
thanks,
this way everything works fine.........
best from germany
Export MIDI Without General MIDI assignments grhufnagl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-24-2009 09:12 AM
Export MIDI produces corrupted data. Unable to export MIDI ! Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-01-2007 07:18 PM
Midi export Toontrack Pro Tools TDM Systems (Mac) 2 08-07-2006 10:13 PM
protools midi export to garageband midi? speky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-23-2006 10:39 AM
Export MIDI ?? Virtual 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-30-2002 08:03 PM
