Old 02-21-2015, 08:56 PM
cStyle cStyle is offline
Default Unable to select in the middle of a bar
When ever I attempt to select within a track I'm unable to select just a portion of a bar. I am forced to select one or more entire bars from the beginning of the bar to the end of it. How do I select in the middle of a bar?
Thanks!
Old 02-21-2015, 09:17 PM
anothercolour anothercolour is offline
Default Re: Unable to select in the middle of a bar
You are in Grid mode with a grid value set to the measure. Either lower the grid value to a smaller value (e.g. quarter note) or change to Slip mode.
Old 02-22-2015, 05:14 AM
Muddy-T's Avatar
Muddy-T Muddy-T is offline
^ That or;
When in grid mode hold down the Command key to place the cursor anywhere.
"Don't look; listen!"
At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6
At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1
Old 02-22-2015, 08:06 PM
You two are rock stars. Thanks so much!
Current Time Locator unable to select all RonCz Pro Tools M-Powered (Win) 0 04-18-2013 06:16 PM
unable to select "find all candidates" in relinking window... duckandcover Post - Surround - Video 3 09-14-2012 01:19 PM
Unable to view (or select) all 4 Inputs in Pro Tools I/O halljr1 Pro Tools M-Powered (Mac) 1 11-27-2007 07:34 PM
Unable to (de)select a...z button Studio Studio Pro Tools TDM Systems (Mac) 2 09-06-2007 05:15 AM
Unable to Select S/PDIF Goodman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-15-2000 02:35 PM
