Old 05-15-2000, 11:41 AM
Goodman Goodman is offline
Default Unable to Select S/PDIF
Using Pro-Tools LE on a 001 interface.
I am unable to select the S/PDIF option (it is grayed out) and use this interface for digital recording. Does anyone know of a workaround for this problem?
David
Old 05-15-2000, 01:45 PM
nuke nuke is offline
Default Re: Unable to Select S/PDIF
If you do a search on this, you'll turn up how to do it.
You have to pick the "Playback Engine..." choice from the Hardware menu, close and save your session, check the S/PDIF option and reopen the session.
Took me a while to figure this out myself.
Old 05-15-2000, 02:35 PM
DigiTechSupt's Avatar
Nuke is correct. You need to open the Setups>Playback Engine>Other Options window to access the Optical Format, S/PDIF monitoring and compatibility features for the Digi001 hardware.
Brent
Avid Audio Tech Support
Support FAQ
Current Time Locator unable to select all RonCz Pro Tools M-Powered (Win) 0 04-18-2013 06:16 PM
unable to select "find all candidates" in relinking window... duckandcover Post - Surround - Video 3 09-14-2012 01:19 PM
Unable to view (or select) all 4 Inputs in Pro Tools I/O halljr1 Pro Tools M-Powered (Mac) 1 11-27-2007 07:34 PM
Unable to (de)select a...z button Studio Studio Pro Tools TDM Systems (Mac) 2 09-06-2007 05:15 AM
888 interface's s/pdif input doesn't like AMIII s/pdif output jmark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-19-2001 01:03 PM
