Re: NY/Parallel Compression - Questions
When blending original drum tracks with a stereo aux with a compressed signal, has anyone found that it messes up the stereo spectrum? For instance, I've found that when I use this technique, that the toms sound weird when I do this... a tom hit from the original track sounds like it's coming from somewhere else in the stereo spectrum than the same compressed tom hit in the stereo bus. The don't line up and the mix loses its tightness. Has anyone else ever experienced this when using this technique?
that probably has to do with phase between the toms and overhead mics. try adusting the panning or fliping the phase of the toms to see if there is any improvment.
Scott Cooke. Mountain View Records |
PTLE 8.0.5, Digi 002 Rack iMac 3.06Hz Intel Core 2 Duo w/8GB RAM, OS 10.6.8 Glyph GT050Q Drives |
Parallel Drum Compression | soundboy35 | Pro Tools TDM Systems (Mac) | 6 | 06-02-2009 11:42 AM |
Parallel Compression in the box. | FraserTSmith | Tips & Tricks | 8 | 05-04-2006 09:21 AM |
Parallel Compression? | SoundguyJP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-28-2006 06:38 PM |
Problem in 6.9.1 w/ Parallel Compression-HELP! | KenSluiter | Pro Tools TDM Systems (Mac) | 22 | 09-16-2005 11:58 PM |
Parallel compression and 6.4 | Aquarius | Tips & Tricks | 2 | 07-05-2004 03:05 AM |
