Old 03-05-2001, 03:07 PM
Vedderman Vedderman is offline
Default Bussing with PT
Hello everyone, I've received and read in many places that PT is vvery "weak" in bussing, actually if you check out Manley's web site and look for the 16x2 mixer it says that "PT has one of the strongest individual channel processing capabilities with all the TDM plugs available, but it also has one of the weakest mixing busses due to squeezing most of the DSP into the channels. They left very little to deal with the buss requirements, which means, that every fader at less than the highest setting, reduces bit depth, so you are not mixing 24bit signals, you are mixing 20 to 12 bits typically"....and so on.....can someone make this clear?....do they mean mixing to 2 tracks or mixing channels alone?
Thanks a lot!
Help a New Guy with Bussing in PT 8 PMcC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-30-2010 12:30 AM
bussing cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 04-10-2007 10:35 AM
bussing genoveva 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2006 03:28 PM
A Little Bussing Help... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 04-04-2006 06:39 PM
Bussing with PT II Vedderman Tips & Tricks 0 03-05-2001 03:49 PM
