Old 05-30-2023, 04:44 PM
Steve@ZooWest Steve@ZooWest is offline
Default PLAY Hangs PT, No Solution Found
PT 12.4 Windows 10 Pro
64 GB RAM
A friend recently fixed some issues with my computer. Afterwards, my PLAY plugins (EastWest and EWQLSO) would hang/crash PT upon attempting to instantiate. I deleted all virus protection programs I could find. Sounds Online support tried to figure it out, using TeamViewer, including a reinstall of PLAY; then downloading and attempting to open Opus, which I didn't have previously, with the same result - Hang/Crash. Log doesn't give any insight. Perhaps I'm not locating a virus protection program? Something else?
Other plugins work fine, including Vienna Ensemble Pro, Ivory, Velvet, etc. etc.
Suggestions?
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 06-06-2023, 04:31 PM
jeam25's Avatar
jeam25 jeam25 is online now
Default Re: PLAY Hangs PT, No Solution Found
Hi have PLAY too with EWSLO strings sometime ago i bought an expansion that habe OPUS player and it is better than PLAY in every aspect and performance. I think PLAY is not optimized for now days systems and OS , i can be wrong tho.
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 06-06-2023, 07:39 PM
Thanks Jeam25. PLAY and Opus are not interchangeable, so Opus won't help me with the hundreds of tracks I've created using PLAY instruments.
Old 06-06-2023, 07:43 PM
jeam25's Avatar
Hi well you can save your Play session file and the Open it with Opus that is what i did when got Opus. I had a lot of instances of Play on different songs so i ask Sounds Online about it and told me so , then i just saved the Plugin Session file and opened in Opus like a charm. Of course the EWSLO are compatible on both Play and Opus, and is the same library.
Protools Ultimate
Old 06-06-2023, 07:49 PM
jeam25's Avatar
Got this from the Sounds Online FAQ page for you :
Will upgrading to Opus affect my current/existing projects?
No, Opus and Play are two separate software products, anything you have saved in your projects will still load up inside the saved Play version of the plugins. You can update your current/existing projects to Opus if you so choose, or leave them saved within Play.
Protools Ultimate
Old 06-06-2023, 08:31 PM
nsureit nsureit is offline
Just a thought. Open Windows task manager and stop/end task of everything running in the background you don’t need to run Pro Tools. I kill all the Adobe crap, AVID Link, Microsoft Office, iCloud, OneDrive, VPN and especially my WD RAID backup app. I also shut off WiFi since I use a USB iLok dongle. When you restart your computer, all these tasks will start running again.
Try it and see if freeing up resources solves your problem. Worked for me.
Was a solution ever found? New Life Records macOS 2 03-17-2013 09:32 AM
Found a new solution to a DAE error...how do i ..? William 2014 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-23-2006 05:20 AM
play loop and nudge (solution found) Bobbers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-15-2005 12:21 AM
- Changing the autoexec.bat file: Solution found (I think...) K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-05-2003 02:11 AM
I found the solution to my 001 or DP3 problem steve0916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-31-2001 10:07 AM
