Old 05-11-2023, 05:22 AM
jcsjohn jcsjohn is offline
Default Instrument Tracks Record Enable
Hi all, just recently my instrument tracks record enable button stops allowing me to record . It's random,,,, one minute the record enable is working absolutely fine,,, then won't allow me to enable it. Keep having to create new instrument tracks. Anyone else having same or similar issues and more importantly,,, does anyone know why this is happening and how to fix it?
Thank you in advance.
Old 05-11-2023, 05:29 AM
Default Re: Instrument Tracks Record Enable
I actually figured it out. Hold down command and click on record button. Not sure why it occurred in the first place.
Old 05-11-2023, 09:05 AM
K Roche's Avatar
K Roche K Roche is online now
Humm well you definitely should not have to "hold command" to get record enable to work so something is amiss
Now this is basic but can we assume you are also record arming the transport every time ? If so then not being able to record arm the instrument track by simply clicking on the button is not correct .
You might try trashing preferences
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 05-12-2023, 02:56 PM
RobertDorn RobertDorn is offline
this has nothing to do with an instrument track. Command+clicking the record button on an audio track or instrument track will 'record safe' the track. When a track is in record safe you can not record enable it, just what Record Safe is designed to do
Just command+click a record safe track, to enable record arm again
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3
Old 07-19-2023, 07:59 PM
skylar_battles skylar_battles is offline
There is some strange behavior in this regard
Instrument and/or MIDI tracks will only "allow" one track at a time to be record enabled if you are record enabling the tracks by clicking. You need to shift click another midi/instrument track to record enable another one in addition to the first one, otherwise it will switch from one record enable track to another track.
All of this can be "ignored" if you select 2 MIDI or instrument tracks at once and hit Shift R instead.
What is frustrating is you can change the behavior of audio tracks to be act like MIDI tracks as far as record enable but MIDI tracks seems to be "fixed" in this way, and I'd prefer the same behavior for both.
Also, Command up and down moves the record enable up or down between tracks that can transmit MIDI data.
record enable two instrument tracks kw88keys Windows 4 06-19-2021 08:39 AM
Instrument tracks not following groups record enable. Ru_C Pro Tools 2020 1 10-15-2020 09:24 AM
disable/enable Bypass plugins on instrument tracks while in record mode Electronic1982 Pro Tools 12 0 05-14-2017 03:52 PM
How do I record enable multiple instrument tracks in a group? grateful macOS 5 03-23-2013 07:12 AM
Record enable instrument tracks in midi editor Intransit Pro Tools TDM Systems (Mac) 8 09-22-2011 02:20 PM
