Old 09-24-2016, 02:09 PM
sandcastle sandcastle is offline
Default Pro Tools 12.5.2 Simply not Getting Input Signals from Apollo
Hi everyone,
I have an original Silver Apollo (4 mic pres+4 lines inputs) as a "master / A" device connected to my Mac Pro via Thunderbolt.
Got a new Apollo 8p connected to the original Apollo also via Thunderbolt ("slave / B").
Running the very latest pro tools (12.5.2.511) + latest El Capitan.
For some reason I can't get Pro Tools to see signals from the "slave / B" Apollo (8p). The UAD console sees the signals just fine, I can monitor them on main outs + headphones... And even record them just fine on Logic Pro X! However, I simply can't get Pro Tools to see the signals so I can record them.
Any ideas, please? I did try deleting the Core Audio / I/O assignments and then pressing "default" multiple times... And believe me, it's NOT an issue with the Universal Audio console as I know how to use it pretty well and Logic sees the signal just fine!! Again, Pro Tools lists the inputs but when I record enable them no signal comes through, bizarre!
I'm starting a session right now, any help would be really appreciated. Tnx
Macbook Pro Retina, OS X Mountain Lion, PT 10
Old 09-24-2016, 03:21 PM
john1192 john1192 is offline
Default Re: Pro Tools 12.5.2 Simply not Getting Input Signals from Apollo
Originally Posted by sandcastle View Post
Hi everyone,
hi, this will at least get you a Bump .. do you need to Delete Current I/O settings and Hit Default to get PT to see your 2nd Apollo, as you say UA software Console sees both units .. not a UA guy so take this with a Grain ..
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 09-24-2016, 03:43 PM
Jantex Jantex is offline
Hi everyone,
Very simple fix. If you have a I/O setup in Apollo Console with less or equal to 32 I/O channels, you only need to press the button Monitor through plugins and Record through plugins and you will get your input signal back. I believe it os a bug on console and by switching between MON/REC through plugins it sorts itself automatically.
Win 7 - UA Apollo working, with Digidesign 003 as Midi input Tripledweb Windows 2 03-17-2013 08:48 PM
Meters are not working on input signals blanc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-23-2006 01:00 AM
still get input signals with input gains down MrShayne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-22-2003 10:21 AM
distorted input signals rmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-20-2001 12:11 AM
MONITORING INPUT SIGNALS OHENEBA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2001 08:31 AM
