Old 05-10-2016, 11:55 PM
Ale Ale is offline
Default Ipad with ethernet! New solution with the new apple USB3 camera adapter
Hi
For all Ipad users that want to get rid of wlan connection follow this link.
Now I could even think of protools dock
http://duc.avid.com/showthread.php?p...41#post2355941
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 05-11-2016, 09:03 AM
john1192 john1192 is offline
Default Re: Ipad with ethernet! New solution with the new apple USB3 camera adapter
hi, but you still need USB power right ?? so you are tied to a short leash .. it is too bad that we cannot put the power on the ethernet line itself and not have to use USB power .. i want to have an ethernet cable and be able to walk 40 feet away ... or cable father than USB power can go ..
Originally Posted by Ale View Post
Hi
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 05-11-2016, 09:24 AM
tom_lowe tom_lowe is offline
I do this with my iPad Pro and have a powered USB hub.
*Ah, didn't realise it was the new USB 3 one!
Old 05-11-2016, 09:35 AM
JuanPC JuanPC is offline
i have the USB2 camera adapter, "480Mbps."
works by using an additional powered USB2.0 Hub, + Apple USB Ethernet adapter. "100Mbps."
but...
a dedicated router, forced/configured to the fastest speed possible,
works as good, and less annoying that having a bunch of cables hanging like an anchor.
on a very dense/cluttered/crowded WiFi area, "all channels used", Ethernet is definitively better.
USB Ethernet adapter has 100Mbps,
some WiFi routers & latest iPads can go faster.
the New USB3 camera adapter speed is limited by the old: 100Mbps, Apple USB Ethernet Adapter.
the new USB3 is just easy to power.
Ipad 4 i have has: Wi-Fi 802.11/n at 2.4 GHz and 5 GHz.
a Router with configurable MCS can go faster than 100Mbps,
https://en.wikipedia.org/wiki/IEEE_8...009#Data_rates
problem is WiFi never goes at 100%,
but Ethernet Always can, if the cable is CAT6
USB2.0 Data Rate is usually 50%, maximum i´ve seen 58%.
--->If you don't like what i wrote:
Click: JuanPC
Click: View Public Profile
Click: User lists^
Click: Add to ignore list.
Solved.
Old 05-12-2016, 10:45 AM
but...
For simply sending control data, you're not going to need anywhere near 100Mbps so that's not an issue.
I've found the latency is far lower, even using an AdHoc Wifi network caused a significant delay, the Pro Tools Control app was stuttering lots and the clock didn't run smoothly either.
I don't care about cables if I get better performance.
Old 05-16-2016, 11:51 PM
Ale Ale is offline
Default Re: Ipad with ethernet! New Eucontrol 3.4 also works wiith PT10
Just want to tell that my unsupported configuration works amazing well
That is:
Eucon 3.4
PTControl 1.06
MacOS 10.9.5
Protools HD 10.3.10
Old 05-18-2016, 06:39 AM
Default Re: iPad with ethernet! New solution with the new apple USB3 camera adapter
Same here, but PT HD 12.4 and the old USB2 camera connection kit with an active USB hub.
Old 05-18-2016, 02:55 PM
astroturf astroturf is offline
it's too bad apple doesnt have an adapter where you can plug in the internet and CHARGE your ipad at the same time. once you get that connector connected you can't charge anymore. i know android has this.
Old 05-26-2016, 07:06 AM
The new one charges as well, just make sure it's plugged into a power adapter rather than a USB socket
HTML code is On
Ipad PTcontrol with ethernet connection Ale Avid S1, S3, Dock and Control App 1 02-16-2016 09:08 AM
USB to Ethernet Adapter jjsoundoc Post - Surround - Video 6 04-16-2015 08:07 PM
Kanex Thunderbolt to usb3/sata adapter Jay_uk General Discussion 7 07-12-2014 10:50 AM
iPad + original mbox + USB camera kit dubpimpjuice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-23-2012 04:33 PM
USB-Ethernet adapter andreasaidu Artist Series 6 02-18-2011 09:16 AM
