Old 09-27-2013, 12:30 AM
mswcpt mswcpt is offline
Default "Extra Long Delay II" Plugin missing
Recently purchased Pro Tools 11 - the "Extra Long Delay II" plugin seems to be missing from my installation. Any ideas how to resolve this?
Old 09-27-2013, 03:17 AM
Stig Eliassen's Avatar
Default Re: "Extra Long Delay II" Plugin missing
I believe it has been replaced by Mod Delay II, and I can't find it anywhere on my systems running PT 10 and 11. It's also not in the plugin finder.
Old 09-27-2013, 03:57 AM
Thanks - will adjust old sessions accordingly.
Old 09-27-2013, 05:39 AM
sunburst79 sunburst79 is offline
It may be in the plugins unused folder. This and a few other plugs used to be listed as superceded in the What's New or Getting Started guides. If they are no longer working in PT11 they may have dropped the references to them.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-03-2014, 11:49 PM
basnettd basnettd is offline
Install of 10.3.3 and then a 'repaired' install still yields,
"Missing or inactive plug-ins
Track "Rhythm Guitar" Insert A ("SansAmp PSA-1") has been made Inactive because the plug-in is not present in the plug-ins folder.
Track "Lead Guitar" Insert A ("SansAmp PSA-1") has been made Inactive because the plug-in is not present in the plug-ins folder.
Track "Delay Return" Insert A ("Extra Long Delay II") has been made Inactive because the plug-in is not present in the plug-ins folder.
Track "Chorus Return" Insert A ("Short Delay II") has been made Inactive because the plug-in is not present in the plug-ins folder.
Missing Stems
The input path "A 1" was made inactive because its stem is missing.
The input path "A 1-2" was made inactive because its stem is missing.
I can only wonder if there is any extra charge for this feature or if I'm getting this for free?
Dell XPS17 with an M-Track Quad
Will supply more technical details ASAP
Old 03-04-2014, 09:18 AM
The old RTAS delay plugins(all 4 of them) from 10 and back, are replaced by a new single AAX delay plugin. No RTAS or 32 bit AAX plugin will work in 11 so you will need to swap out for the new plugin there.
As for the inputs, start with Setup>IO>input tab and see what paths are available. Maybe you need to reset IO or rename, or delete all paths and hit the DEFAULT button
In the long run: "PT10 Student + CPTK" or "PT10HD"? Funky Monk Pro Tools 10 22 03-16-2013 09:46 PM
"Error, missing ILok authorization for "Pro Tools 10". johkav macOS 4 09-10-2012 08:13 AM
Click, D-verb, Extra Long Delay II, Short Delay II are missing in PT10 UPGRADE ruxandra Windows 6 06-20-2012 05:29 PM
Plugin Sharing Bug!!!! Extra Long Delay M2E Pro Tools TDM Systems (Mac) 12 07-08-2007 05:50 AM
Delay Plugin with "TAP" function DBX165 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-16-2002 12:45 AM
