HD Native (new install) DAE error 9514 preventing Pro Tools load
I've just upgraded my system from Pro Tools 10.3.4 + CPTK (002 Rack) to an HD Native (10.3.5) + Omni I/O system. I fully removed the existing Pro Tools install, powered down, installed the native card and followed the usual procedure for installing the software (UAC/anti-virus/wifi all off, of course...drivers first, restart, software, restart). First load of Pro Tools prompted to update the firmware on the HD Native card...done, and restart. Then ran DigiTest to update the firmware of the Omni (it's now on revision 2.10). Restarted the system, attempted to load Pro Tools, and got this error:
"Could not allocate memory for the disk cache. Try lowering your disk buffer (DAE Buffer), disk cache, or voice engine count. If you got this error on launch, delete your prefs and try again. (-9514)" Followed the suggestion and restarted. Same error. Repeated that and held "N" while loading Pro Tools to bring up the Playback Engine dialog, adjusted everything to their lowest settings, and still got the same error. Did a full uninstall of Pro Tools/drivers/etc., restarted, and repeated the install process. Error persisted. Just for the hell of it, I even tried installing 10.3.4 and 10.3.1...all to no avail. HD Native Card and Omni I/O pass all processes in DigiTest. So, I know the HD card is properly seated. The software just won't load up. Anyone have any other ideas I can try before going through a full system clean install? Here's a Sandra report. I realize I'm running a bunch of "unsupported" hardware components, but it's a custom system that I built, almost 3 years ago now, that has given me absolutely zero issues with the previous Pro Tools installs. Then again, this is the first time I've installed an HD card of any flavor in it. Thanks in advance for any assistance. Computer Model : GigaByte GA-990FXA-UD5 Chassis : GigaByte Desktop Mainboard : GigaByte GA-990FXA-UD5 BIOS : Award (OEM) F9 05/30/2012 Total Memory : 32GB DIMM DDR3 Processors Processor : AMD Phenom(tm) II X4 965 Processor (4C 3.42GHz, 2GHz IMC, 4x 512kB L2, 6MB L3) Socket/Slot : AM2r2/AM3 Chipset Memory Controller : AMD F10 Athlon 64/Opteron/Sempron HT Hub 2x 2GHz (4GHz), 2x 16GB DIMM DDR3 1.34GHz 128-bit Memory Module(s) Memory Module : G.Skill F3-1600C9-8GSR 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-1600C9-8GSR 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-1600C9-8GSR 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-1600C9-8GSR 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : Samsung SA300/SA350 (1920x1080, 23.0") Monitor/Panel : Samsung SA300/SA350 (1920x1080, 23.0") Video Adapter : ATI Radeon HD 5800 Series (20CU 1600SP SM5.0 875MHz, 1GB DDR5 5GHz 256-bit, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 5800 Series (20CU 1600SP SM5.0 875MHz, 1GB DDR5 5GHz 256-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : ATI Radeon HD 5800 Series (1600SP 20C 875MHz, 1GB DDR5 5GHz 256-bit) Compute Shader Processor : ATI Radeon HD 5800 Series (1600SP 20C 875MHz, 1GB DDR5 5GHz 256-bit) Storage Devices SAMSUNG SSD 830 Series (256GB, SATA600, SSD) : 238GB (C:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (D:) WDC WD20EARX-00PASB0 (2TB, SATA600, 3.5") : 2TB (E:) Optiarc DVD RW AD-7240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices MainHD (C:) : 202GB (NTFS) @ SAMSUNG SSD 830 Series (256GB, SATA600, SSD) WorkBench (D:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) Library (E:) : 2TB (NTFS) @ WDC WD20EARX-00PASB0 (2TB, SATA600, 3.5") Optical Drive (F:) : N/A @ Optiarc DVD RW AD-7240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ATI (AMD) IXP SB600/700/800 SMBUS Controller LPC Hub Controller 2 : ATI (AMD) SB700/800 LPC host controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Gigabyte IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : PC Partner Cypress HDMI Audio [Radeon HD 5800 Series] Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Disk Controller : Gigabyte SB700/800 SATA Controller [AHCI mode] Disk Controller : Gigabyte 91xx SATA 6G Controller Disk Controller : Gigabyte 91xx SATA 6G Controller USB Controller 1 : Gigabyte SB700/800 USB OHCI0 Controller USB Controller 2 : Gigabyte SB700/800 USB EHCI Controller USB Controller 3 : Gigabyte SB700/800 USB OHCI0 Controller USB Controller 4 : Gigabyte SB700/800 USB EHCI Controller USB Controller 5 : Gigabyte SB700/800 USB OHCI2 Controller USB Controller 6 : Gigabyte SB700/800 USB OHCI0 Controller USB Controller 7 : Gigabyte SB700/800 USB EHCI Controller USB Controller 8 : Gigabyte Etron USB 3.0 Extensible Host Controller FireWire/1394 Controller 1 : Gigabyte VIA VT6308 1394 OHCI Controller SMBus/i2c Controller 1 : ATI SB800 SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : Belkin N+ Wireless USB Adapter (802.11g (ERP), AES-CCMP, 144Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 7.4 |
Re: HD Native (new install) DAE error 9514 preventing Pro Tools load
As an update to my ongoing attempts to trouble shoot, I've tried moving the HD Native card to the 1st PCIE x4 slot, and tried loading Pro Tools without the card installed (using a Sound Devices USBPre 2 as the ASIO device)...still get the same error.
I would recommend a clean install period. It's a terrible amount of time, but nothing is better. Preferable to take some images along the way with something like acronis or drive images w Casper. That way you can always revert to a clean state.
Pull your wireless stick out. Turn aero (desktop composition) off? Use my Trasher app (use appropriate version) to delete your Dae, PT prefs, and databases. That would be about all I could recommend.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
+1 to a clean Windows install.
I usually do the install, all windows updates then do a backup image. Then install PT/card/drivers etc and do another image. Of course don't forget to backup anything you want saved before wiping the OS drive.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Problem solved. When you activate the software through the website, it gives you a step-by-step set of instructions for installing. One of the things you're told to do is download the latest hardware drivers (of which there is a separate file available). What I didn't know, or see any instructions about, is that you're not supposed to install them from that additional download if you're using the hardware with Pro Tools. I had done that, and that's what was causing my issue. Apparently, that file is only to be used if you want to use the hardware and aren't installing Pro Tools.
Pro Tools Startup Error -9514 | frank1985 | Pro Tools 10 | 3 | 12-05-2012 03:09 PM |
Pro Tools 10 on Windows 8 (error 9514) | [email protected] | Windows | 9 | 11-08-2012 01:32 PM |
Pro Tools 10 Launch Error (-9514) "Disk Cache (DAE)..." | mgthefuture | Pro Tools 10 | 5 | 03-03-2012 09:59 PM |
Javascript preventing Transfuser install | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 31 | 02-25-2011 01:32 PM |
Pro Tools 8.0.3 won't load after initial install | The.Musical.Director | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-26-2010 04:22 AM |
