Go Back   Avid Pro Audio Community > General Discussion & Off Topic > Buy & Sell
Old 07-09-2012, 03:41 PM
MichaelLewisMusic MichaelLewisMusic is offline
Default WTB: Magma PE6R4 Expansion Chassis
Found my PE6R4. No longer looking, thank you!
Thank you!
Michael Lewis
The Song Mill
Coeur d'Alene, Idaho
Last edited by MichaelLewisMusic; 07-21-2012 at 02:08 AM. Reason: No longer needed
Old 07-19-2012, 02:30 PM
XmenX XmenX is offline
Smile Re: WTB: Magma PE6R4 Expansion Chassis
Originally Posted by MichaelLewisMusic View Post
Upgrading to Mac Pro and looking for a good deal on a PE6R4. Ready to buy at the right price.
Thank you!
Michael,
PE6R4 is an older version. This is an obsolete model.
The newer version is PE6R4-I model.
PE6R4-I, here is the video
http://youtu.be/qBkgiUKIvqs
Here is a video showing the differences between PE6R4 and PE6R4-I
http://youtu.be/_rgtdr3bnTk
Old 07-19-2012, 02:34 PM
Default Re: WTB: Magma PE6R4 Expansion Chassis
Thank you Xmen -- so I've heard. Other than the type of cable, I don't really see the difference? I also haven't heard anything that would make me think it won't work with my system (2008 Harpertown) just as well as the newer one would. If you know any details to the contrary, I would appreciate hearing it.
And did you have one you wanted to sell?
Thank you!
Michael Lewis
Originally Posted by XmenX View Post
Michael,
Michael Lewis
The Song Mill
Old 07-19-2012, 05:40 PM
justus1900 justus1900 is offline
I have one but I dont know what Model it is? How do I tell?
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 07-20-2012, 04:14 AM
There should be a model number on the serial number identification plate which is probably on the back or the bottom of the unit.
Michael Lewis
The Song Mill
Old 07-20-2012, 04:29 AM
Oliver M Oliver M is offline
Michael,
both models will work just fine, the only difference between them is the host card and cable. The PE6R4-I is the newer one but the older PE6R4 is the one Digidesign (Avid) approved officially. I once had the PE6R4-I and it worked great. Just make sure your HD core card is NOT a revision K card as this one would need fixing from Avid which costs several hundered dollars. The revision K cards throw DAE errors -1115.
See this thread: http://duc.avid.com/showthread.php?t=291518
Oliver
Old 07-20-2012, 04:34 AM
Originally Posted by Oliver M View Post
Michael,
Oliver
Thanks Oliver -- so is there any difference in speed between the R4 and R4-i? I read something that said the R4-i will do x8 but the R4 only does x4? I don't even know that that means but it sounds like it could be a concern? Do you know anything about that?
Thanks again!
Michael
Michael Lewis
The Song Mill
Old 07-20-2012, 04:46 AM
Thanks again!
Michael
No I don't Michael. I would contact Magma regarding this. Of course it is always best to buy the latest model, the PE6R4-I in this case, regardless if new or 2nd hand but if you come across a PE6R4 cheap I would go for it in case you intend to use it for Pro Tools only.
Oliver
Old 07-20-2012, 09:57 AM
DucoLax DucoLax is offline
Thumbs up Re: WTB: Magma PE6R4 Expansion Chassis
Thanks again!
Michael
PE6R4-I, its host card is X8
PE6R4, its host card is x4
***New PE6R4-I , the I stands for Ipass
1. One Ipass cable,
2. mezzanine card (with one X4 port)
3. X8 host card
***Old PE6R4
1. two Infiniband cables,
2.mezzanine card with two ports
3. X4 PCIE host card
FS: Magma Expansion Chassis PE6R4 (Denmark) Peterjk Buy & Sell 4 07-09-2012 09:33 PM
Magma Pe6r4-i Epansion Chassis tvent Buy & Sell 0 06-09-2012 11:41 AM
Anyone Run PT 8 TDM with the Magma PE6R4 Expansion Chassis kd_special Post - Surround - Video 4 09-23-2010 06:26 PM
Bugs with Magma PE6R4 Expansion Chassis [email protected] Pro Tools TDM Systems (Mac) 3 07-06-2007 12:04 AM
Digidesign distributes Magma PE6R4 Expansion Chassis Dutchmuzik Pro Tools TDM Systems (Mac) 6 03-23-2007 07:22 AM
