Old 06-18-2012, 05:03 AM
CristiDobrica CristiDobrica is offline
Default HD Core instead of HD Accel in a Magma Chassis
Is it possible to put more than 1 HD Core card in a multiple card configuration? Specifically I have 2 Core cards and 3 Accel cards on PCI-X and i want to put all of them in a Magma PE6R4 Chassis. Will the extra Core card act as a Accel Card if it is the last in the chain and just give me more power or is it possible to cause problems (errors) ?
Old 06-18-2012, 06:13 AM
janmuths janmuths is offline
Default Re: HD Core instead of HD Accel in a Magma Chassis
Hi CristiDobrica, only one core card per system. The card order is usually core card first, then accel, then process. But before you start look up the manual for the magma and read the avid docs on expanded systems.
Hope this helps,
Jan
2010 Dolphin Award for Production / Engineering
AVID Certified Instructor
Old 06-18-2012, 06:55 AM
Drew Mazurek's Avatar
Yes. A core card in a position other than first, will act as a Process card.
www.drewmazurek.com
Old 06-18-2012, 08:08 AM
WernerF WernerF is offline
Yes, as a Process card, not an Accel.
Digidesign Chassis? Magma Chassis? BigEvil Pro Tools TDM Systems (Mac) 13 12-13-2008 10:53 AM
PCI HD Accel cards, Magma pci chassis and newer PCIe Macs CD Productions Pro Tools TDM Systems (Mac) 8 10-07-2008 08:03 AM
Adventures in 8-core and Magma chassis land Top Jimmy Pro Tools TDM Systems (Mac) 9 08-21-2007 08:29 PM
Runing Accel plugs on the "Accel PCIe core DaveSB Pro Tools TDM Systems (Mac) 0 12-19-2005 10:25 PM
Magma Chassis for HD2 Accel Imagine Pro Tools TDM Systems (Mac) 6 07-11-2004 08:02 PM
