Old 01-12-2010, 03:12 PM
-GS- -GS- is offline
Default Merge Multiple Pro Tools Sessions
Hello everybody, I tried to find something suited to my needs in the DUC but failed. If this topic has already been covered in detail, please close this thread and redirect me to the correct one (and sorry for the waste of your time).
I need to merge two Pro Tools sessions and I have problems. The “Import Session” command works just fine, but I still haven’t figured a way to keep BOTH sessions’ Markers, Tempo and Meter Change.
Let’s make an example: I want to merge “Session A” with “Session B”. I create a whole new session. From inside this new session, I click “Import Session”; then select the tracks I need from “Session A” as well as “Tempo”, “Meter” and “Markers”. Done. No problem.
Then I repeat the process for “Session B”. Here come the problems: all OK with the tracks to be imported, but when I try to import Tempo, Meter and Markers, the old ones are automatically deleted / overwritten! I have tried moving ahead the old data (let’s say 100 measures away) hoping to do the trick, but that didn’t work.
How can I keep both data? I have used *A LOT* of Tempo / Meter changes and Markers in both Sessions, and don’t want to lose them all (well... at least a part of them!)
Thank you in advance
GS
Old 02-14-2010, 04:26 AM
Intersound Intersound is offline
Default Re: Merge Multiple Pro Tools Sessions
Yeah, same question here.
I actually want to import marker tempomap information from another session into my current session (with an offset of e.g. 100 bars)
I tried with "import midi" and "spot" mode, but it will delete all other markers and tempo information BEFORE bar100 (?).
Any help very much appreciated, thanks.
Intersound
Old 02-14-2010, 05:16 PM
Kirby B. Kirby B. is offline
to the original poster, I don't think this is possible, at least in LE.
Old 02-14-2010, 11:36 PM
@ Kirby:
I, too, fear this is the answer.
But I'd be curious to know if this function is implemented in HD.
Old 02-14-2010, 11:46 PM
caruso7r caruso7r is offline
I don't know if this relates to what you are talking about but for years I always wanted Pro Tools to open more than one session at a time so I could drag regions between two or more sessions. Kinda like a "sync" function for what I was doing a few years back. Sonic Solutions did that and saved alot of time when it came to comparing "EDL's"
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 02-15-2010, 12:32 AM
@ caruso7r:
I didn’t know about the existence of a sequencer by Sonic Solutions. I’m taking for granted that it isn’t compatible with Pro Tools format (in other words, I won’t be able to get past my problem by using it in conjunction with PT).
But yes, the problem is that, basically, Pro Tools still can’t deal with more than one session at the same time. It would be so easy to just drag-drop portions of a session into another. Let’s hope that, in future versions, this will be possible.
Old 02-15-2010, 12:47 AM
Sonic solutions is not a sequencer at all. Strictly audio, no midi what so ever. I guess I didn't read your post well enough.
John
Pro Tools 12.5
Old 02-15-2010, 01:20 AM
No, sorry, my fault, I thought you were talking about a new kind of sequencer by Sonic Solutions which allowed "trans-session" copying/pasting.
I'll just have to come to terms with it... and manually copy all of the tempo / metre changes as well as markers (I should quit writing Polyrhythmic music and stick to 4/4 throughout! Less effort... Meshuggah are to be blamed! )
Thanks
GS
Old 02-16-2014, 07:05 AM
djswave1 djswave1 is offline
Response to original post.
Session Data Merge (w tempo markers,etc)
https://www.youtube.com/watch?v=ZIzLKzg8tEk
Breaking up multiple songs in one session into multiple sessions? rmandelbaum Windows 10 08-14-2013 10:05 PM
How to merge several separate PT sessions into one ? Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 03-04-2011 05:56 PM
Merge Multiple MIDI regions to one. PT8 audiogeekzine MIDI 3 01-22-2010 11:13 AM
how do U merge sessions w/different frame rates??? ejsongs Pro Tools TDM Systems (Mac) 6 09-16-2005 08:50 PM
Multiple sessions in PT cham Tips & Tricks 2 12-01-1999 01:14 PM
