Old 01-08-2024, 04:35 PM
s.d. finley s.d. finley is offline
Default Re: Runnind PT 10 and 003 Factory with NEW 2024 Mac
Originally Posted by PRSWILL View Post
Well as someone said, i'll probably go "half-way" and find an older- yet newer mac with a little more ram, faster chip set, etc but will still run my stuff. I am not ready to throw in the towel on this gear- I know how to use it and have a LOT of plug-ins and virtual instruments that I really don't want to replace.
No Firewire driver in Ventura and beyond. 003 sounds horrid anyways. Pre amps are mostly useless. Most plug in developers give you both RTAS and AAX.
And PT 10? good luck with using that on an AS Mac! Just buy a MacPro 5.1 and install Mountain Lion. I have a copy. Max out the 5.1 with RAM and you can update the CPUs if they aren't already the fastest for that model. Cheap.
sdf
www.sugarhillstudios713.com
Old 01-08-2024, 05:00 PM
In general Firewire Audio interfaces on Ventura should work, or can be made to work. There are many many posts on the Interwebs explaining how to do this. It should not be an issue.
Getting Pro Tools 10 to run on Ventura, or not having a 003 driver for Apple Silicon OTOH are entirely different matters.
Old 01-08-2024, 06:02 PM
oh well then good news! The OP can still rock the 003! kind of
sdf
Old 01-09-2024, 02:29 AM
fresler fresler is offline
That's exactly what my daily driver was till a few years ago. Mac Pro 5.1, dual processor, venerable Digi002r, Pro Tools 10HD on Mac OS 10.9 (Mavericks).
I'm still on the Mac Pro, but moved to Mojave, Pro Tools Ultimate 2023.12 and a basic UMC1820 for audio monitoring... I'm missing a few RTAS plug-ins (like Cosmonaut Voice) but everything is pretty solid.
Luca de Sensi
Old 01-11-2024, 02:42 PM
I am still using a cMP 5.1 at my personal studio. Did the Mojave update and used DosDude Catalina patcher. Lynx AES card and a Crane Song HEDD for I/O. I am using PT 2023.6. No issues with 2023.12? I may try to update the 5.1.
sdf
Old 01-11-2024, 03:41 PM
For me, 2023.9 and 2023.12 are doing ok.
You have to move out of the application package the Sketch part and you are all sorted.
Only issue encountered so far in 2023.12, internal renderer is working fine but Pro Tools will hang and crash as soon as you click on the Windows menu: Dolby Atmos Renderer.
... not much of a problem for me, as I'm still on Dolby Atmos Production Suite...
Luca de Sensi
Old 01-11-2024, 05:51 PM
basslik's Avatar
basslik basslik is offline
I've seen some posts/videos with some "how to" guides on making this actually run. I'd really appreciate some professional advice on this. I really don't want to have to re-buy all of the RTAS plug-ins and i don't want to scrap my 003- it's an awesome piece of gear. BUT - i do want to use a faster mac with a lot more RAM.
Any insights on this would be appreciated. Thanks!
I'm still running my 5,1 Pro with my digi 003 rack & Console.
New Mac's are stupid expensive, and clearly my supped up Mac Pro does everything I need it to do, even when I was on Mojave.
You can run PT 2023.12 with any version of MacOS up to Monterey with this video install. https://www.youtube.com/watch?v=F0jq8CXJRBU
The only problem I'm having is I have to force quit PT. But others seem not to have my particular problem, and perhaps due to they have different interfaces.
I"m curious enough to see if Sonoma will work with my Digi 003 ?
Will install and see if it works.
*Also a side note*. if you use Martin Lo's script you can boot into any older OS combo's, via boot picker, let's say Mt. Lion with PT10 if you needed to.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 01-13-2024, 04:59 PM
PRSWILL PRSWILL is offline
Yeah? NOT- the pre-amps in the 003 are very good. We've released 4 albums with more than 1,000,000 copies downloaded/sold for 5 bands using these. There's a lot more than pre-amps that go into making a solid album.
Old 01-14-2024, 09:42 PM
basslik's Avatar
Great to hear that.
Noob here, but I noticed from my Digi 003 console going to a Digi 003 rack with the BLA Signature Mod I can clearly tell the difference in the low end definition.
Indeed there's a heck of a lot more than the pres. I'm a sponge and suck up as much knowledge you greats are spill on us.
Greatly appreciate it.
Old 01-16-2024, 04:45 PM
Yes there is a lot more than pre amps that go into making any music. I am certain the 003 Pre amps weren't the selling point of the music either!!
Good for you getting the most out of the 003!
I have owned 001, 002, 003 and still use my C/24. Oddly 001 had the best pre amps of the lot IME. That might have been because digidesign didn't completely cheap out on the pre amp then. Not ideal but they weren't noisy and were sonically in the ballpark with each other. I don't use the C/24 pres as they are noisy, timbre doesn't match between them and neither does the gain. I do enjoy the C/24 as a control surface. I skip the monitor section with a Crookwood too.
sdf
[FS] $350 [104 Waves Plugins] SSL CLA API Puig Tape DIAMOND Vinyl OMNI Abbey WUP 2024 Electronic1982 Buy & Sell 2 12-05-2023 02:35 PM
[FS] $299 [28 Waves Plugins] SSL CLA API Puig Tape Vinyl OMNI Abbey Kramer WUP 2024 Electronic1982 Buy & Sell 0 11-26-2023 01:58 PM
003 Rack Factory - where is Factory Software installer stevedemena 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-19-2010 06:42 PM
how to authorise Bomb Factory plugins w/ Factory 001 bundle MGalway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-05-2002 10:34 AM
