Old 05-23-2023, 04:23 PM
Hanswurstlsepp Hanswurstlsepp is offline
Default Structure2.0.11 crashes PT23.3
I'm running a M1-Mac Mini with 16 GB Ram and macOS Monterey Version 12.6.5.
When I'm opening the Structure GUI and Structure is trying to resolve missing samples using Spotlight, PT 23.3 crahes.
I'm using Structure Version 2.0.11.5fe75c.
On my MacPro running the same PT & Structure Version BUT the macOS is Catalina, all is fine.
So it might be a Structure incompatibilty issue with Monterey.
Anyone with a workaround or any hint to resolve the problem ? Right now Structure is unusable for me ...
Thx
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 05-23-2023, 07:38 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: Structure2.0.11 crashes PT23.3
Hi STeff
Structure 2 is supposed to be compatible with Monterey, according to:
Structure 2 (macOS)
macOS Catalina, Big Sur & Monterey Compatible (M1 Mac not supported)
Here’s the link for Structure 2.0.11.210
https://help.pluginboutique.com/hc/e...-Download-Area
https://www.pro-tools-expert.com/pro...023-3-released
24 Mar 2023 — In the short term AAC Import and the Structure Free AIR virtual instrument are also not supported, but will be soon.
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 05-23-2023, 08:45 PM
Eric Lambert's Avatar
I agree, I don't think it's the OS giving you trouble with Structure. It should be fine with Monterey. It's even fine here with Ventura.
Old 05-24-2023, 02:55 AM
Thx all for the infos.
I was wondering if the problem might be a MacOS version because Structure used to work with BigSur (macOS11) in 2021.
Thx
Cheers, STeff
Old 05-24-2023, 03:46 AM
Stephen Bond's Avatar
Structure still soldering on here, though not the latest and greatest OS/PT combo
Structure 2.0.11.5fe7f5c Copyright 2021 AIR Music Technology
Mac OS Monterey 12.6.5 (21G531)
Pro Tools 2022.9.0
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 06-05-2023, 01:29 AM
bledi bledi is offline
I opened a case with avid as structure free was crashing PT. The bug is known from avid's side and they said they are still working to fix the issue with Air.
Pro Tools 12 crashes and crashes... Phantobias Pro Tools 12 12 09-15-2015 11:08 AM
PT Crashes and crashes again... Help needed! heabow macOS 5 01-23-2015 02:44 AM
Structure2 installation problem Kinh Virtual Instruments 8 07-11-2014 09:02 AM
PT LE 9.01 Crashes with Mac OS X 10.6.6 gazblake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 42 03-10-2011 08:53 AM
PT7.cs8 crashes when there is not enough DSP peter99 Pro Tools TDM Systems (Mac) 2 06-19-2006 07:49 AM
